2.1 Lite!!! Option 4
I've been noticing a bizarre bug with this 2.1 lite package. At random any kind of audio output goes bye-bye... calls through the receiver, speaker, notification sounds, ringer... I mean everything. Also, when this happens, if I press the volume up/down button to change the ringer volume, the phone lags HARD and then will either lock up on me... or just reboot on it's own. Any ideas?
Read this it's not the best answer. http://forum.androidcentral.com/htc-hero-roms-hacks/9769-sound-drops-out-android-2-1-a.html
I wonder if audio issue is on phones marked Google on the back or not or is there a manufacture before/ after date?
There would almost have to be some common factor.
I don't go on xda much, does anyone know if anyone has found a commonality?
I think all the factors have been looked into read the link above gbhil post pretty much covers it.
I ended up flashin the ERIS patch, and the audio problem is gone... thank goodness :)
I just realized tho... VVM is gone :(
Can someone post the files to push via ADB? ^^ (or is this not possible)
The second post has the zip with vvm in it you can just flash it threw recovery.
Hey I downloaded this 2.1 lite & some of the apps that require root access are not working for me. Drocap2 was working at 1st but now it doesnt. I just get a black screen when I try to take a pic. I downloaded setcpu from the xda site and intalled it through Astro. After I click on the hero option and the app tries to get root access I am left with nothing but a blank screen. Can anyone help?
Setcpu won't work with any of the 2.1 roms that are up here.
Also make sure usb debugging is selected if you get just a black screen when tryin to get root access with drocap2.
Thanks. The drocap tip worked. Do you know if setcpu will ever be compatiible with the 2.1 roms?
It will be soon or later.If i understand it right we need the source for the new kernel before it can happen.
I flashed Option 4 today. Went great took all of 5 minutes to reboot!
I think I need to do apps2sd but don't have a clue on how to back up the sd card. I assume partitioning means it gets wiped in the process?
Looked at a few threads but makes no sense to me.
Yeah, you're right, it wipes everything off of it.
Just mount the card to a computer and copy/paste into a folder. You can just copy paste back to the card after partitioning.
Apps need to run off of an EXT partition, everything else gets stored into a FAT32 partition. The longest part of the process is backing up and restoring.
Thanks! I'll give it a go hopefully tonight.
Does this automatically set partition sizes or do I have to do that? If I do, what sizes? I just have the 2gb card.
reblkari666
