2.1 Lite!!! Option 4
hmmm, ok so i went back and put the swap-size back to 32, and now my HTC Sense keeps force closing... i've been using HTC Sync's ADB to get it into reboot recovery, and I can turn on HTC sync, but I can't do the USB debugging from the phone... so i'm not sure how to reboot...
anyone have any advice?
PS - thanks sooo much for your help and patience.
If your in the recovery you should have a option to reboot system now.
I'm not. i can't get into it, it's stuck in a cycle of force closing the HTC Sense launcher, so I can't turn on USB Debugging to launch ADB through my command prompt.
Is there another way to get to it?
***EDIT*** I was able to get into it, nvm! Gonna reboot and check back.
If you can't connect to a cp then you'll have to pull the battery out.I've had to do that a million times.Then once you put battery back in hold the home button while pressing the power button don't let go of home til the recovery menu pops up.
Okay, still force closing on the HTC Sense. Here is how I have it partitioned:
swap-size: 32mb
ext2-size: 512mb
and then the rest on the FAT32.
This is the last change I made since it started doing this... Did i do something wrong?
(Should I start this be moved to a new thread also?)
swap-size: 32mb
ext2-size: 512mb
You good with posting here,You have patitioned right.I would re flash the rom then you shouldn't have a problem.
Ok, quick dumb question... i am using option 4, so I flash the rom, then the voicemail.zip, and then I'm good? Do I need to Wipe anything like i did the first time I flashed?
You will have to wipe it won't flash over,ive tried.lol Then you have it right wipe flash,then flash voicemail you should be good to go.
You have to wipe everything.
If you get error 387 you didn't wipe ext.(i forgot to):o
Okay, so I've wiped ext twice now, both times i'm getting failure at 387. this is going to be the death of me! i'm too young!! LOL but seriously... am i missing something?
This has probably been asked at some point in one of these threads, but there's a lot to go over and it would take a lot of time. So sorry if this is a repeat question...
Now that I've flashed it and it's working alright (thank you :) ), do I need to keep the img file on my SD? I plan on keeping a backup on my computer regardless.
nah, you can remove it.
can i revert the sprint RUU Leak or use another option, please helph me i would like to get wifi tether, but more than anything i would like for my phone to run better this RUU crap lags more than when new. PLEASE HELP!!!!!!!!!!!!!!!!!!
I know this is probably a small deal but i got really used to seeing the photos for all linked facebook contacts in my "People." There is some sort of bug with the HTC for Facebook that doesn't allow me to link profiles for contacts whose names are after the letter "J" ...? Any ideas?
Did anyone figure this out? This is actually a bigger issue for me, as I used the features that went along with the linking on a daily basis. t's no biggie that they didn't re-link automatically when I flashed the ROM, but when I go to link them myself I can't get past the end of letter B. So I'm kinda missing a lot of people.
In addition, all of the birthdates are wrong. And when you go to manually set them, it doesn't take what you set it as. It throws it off by a month and day or two.
EDIT: First two times restarting, nothing happened. The third time, it fixed itself. Go figure. Birthdays still are wrong though, don't know why...
I don't understand it either - I didn't have the Facebook issue, that I've noticed. But for some reason with this rom, it took about a week and 3 to 5 reboots for everything to just sink in and starte working. I think the only thing that really never worked was Google Nav. Sound issues are fine, live wallpapers got less quirky.
beezy420,
Nice job on the option 4, I installed it yesterday and runs smoothly.
On the other hand, I added the voicemail and sprint nav without wiping anything. Should it be an issue?
Got a message today from the Google team congratulating me on my Nexus One purchase after installing 2.1 LMAO, anybody else get that message?
beezy420,
*Thank you. You shouldn't have any issue.
Yeap,everyone gets aleast one.lol
liquidsnake757
