2150 mAh battery and I LIKE IT!!!!
Probably not, since heavier objects don't actually fall faster than light ones. There is a grain of truth to your theory because it would change weight distribution against the air resistance as it falls, but unless you're dropping it off a third floor window, air resistance isn't going to have enough time to make much of a difference.
Just trying to be funny here - but if the weight doesn't matter then why does a piece of bread with peanut butter on it always land peanut butter side down? :-)
Need for Speed superceded by the need for Juice!
:cool: Had the 2150 in for a couple days now... Definitely better than the OEM battery and better than the 1750. I'm still playing and getting the D-Inc set up with the apps and learning how to navigate so my drain is still pretty extensive on the 2150mAh. I'm going to keep the 1750 around for when I need to slim 'er down to fit into an available case for the "Light Flights". ;)
the 2150 isnt raelly that big. the original pics of it naked makes it look just ugly. but in reality it isnt much bigger than stock if you're using a case. i have the black silicone case from Verizon and i basically just cut out a spot on it so the lump of the battery could pertrude and it doesnt stick out much more than when there was a piece of rubber there (the case). My hand actually holds it better and I like the heaviness it adds to the phone.
... so far.. it's been unplugged since 5:30am.. now 9:30am.. 4 hours.. used it to surf facebook, talk 30 minutes on the phone, update a few apps.. and it's at 89%. my seidio 1750mah battery would have been at 70 or 75% by now.
I'll update by the end of the day/night before I charge it to see.. usually on my daily routine my Seidio 1750mah would be about 20-30% by the end of the day with moderate use.. from 5am until 9pm unplugged.
i'm at almost 5pm (almost 12 hours since unplugged) and I'm at 85%! although while at work I haven't used it much. It does vibrate occassionally when I get emails.. and I did check Facebook while on lunch.. oh and I installed/downloaded an App from the market. but yeah 85% at 5pm and unplugged at 5:30am.
I wonder though if me charging it last night.. (charged all night long).. with the phone OFF makes a diff versus charging with the phone ON. going to test it tonight. hopefully it's not a HUGE difference. I like my phone on at night in case I get important phone calls.
Nazeer zaheen
