4.2.2 Update
Just got the update myself with the 16gb WiFi only Nexus 7. Seems smoother. Trying they auto brightness now.
Seems that auto brightness is better in bright rooms. I will have to try in low light later tonight.
I was using my tablet in the dark last night after side loading the update and the auto brightness kept flickering constantly.
Sent from my Nexus 7 using Tapatalk HD
Just got the update for my 8gb Nexus 7. Seems faster overall. I had a lot of lag when the tablet was waking up with a smart cover which has pretty much dissipated now.
Anyone that has gotten the update and uses HD Widgets know if the update fixed the rebooting issue?
I never had the rebooting issue before with hd widgets so I'm not sure this helps you that much but so far no reboots and i am still using hd widgets.
I stopped using my 7 because it turned into a slothful piece of molasses. I bought one of the first units. Hopefully this update will give me my old 7 back.
My N7 just updated to JB 4.2.2 . Build number JDQ39.
If anyone hasn't gotten the 4.2.2 update yet, I followed these steps and it forced the update. Your results my vary but it worked for me:
1. Go to Settings -> Apps -> All
2. Find Google Services Framework
3. Tap on Force Stop
4. Select Clear Data
5. Head back to the Nexus 7?s Settings, go to About, and check for a System Update
Instructions courtesy of - How to Get the Nexus 7 Android 4.2.2 Update Right Now
After I finished posting my previous post received the update
It does work. You may need to do it a couple of times. It took me four times before the update started to download. Thanks for the tip, Bronson!
Wow worked on 2nd try using this method! Gracias!
Update: Downloaded at least 4 times and keep getting error. Will return to 100 % stock and try again tomorrow.
So, my N7 is on stock 4.2.1, which I sideloaded over adb sideload. When I tried to manually update to 4.2.2 the same way, I got this:
The recovery screen also has a big red exclamation mark and says "No permissions". Little help?
Mine just updated this evening after clearing the Google Services Framework. No problems so far. Eighty-eight apps optimized and about a dozen downloaded updates.
liquidsnake757
