5.1.1
On Verizon. Pulled out the Sim and checked for the update. LMY47Z popped up and updated. Then I just simply put the Sim card back in.
If you really want it early the trick that usually always works is pull Sim, factory reset phone, search for update, install update that pops up, then re install Sim. That's what I did for 5.1. Of course u have to set ur phone back up after the way u like it.
I just received my Nexus 6 from Motorola today. Instead of pooping in my Verizon sim card I just connected to wifi and 5.1.1 was ready to be installed. Worked like a charm and no my phone is up and running 5.1.1 on Verizon. excellent.
Google shouldn't take two months to deliver something they say should take up to two weeks.
I tried that the other day and it did not work, I pulled the Sim, reset the phone and tried to update but no luck
If lmy47z works on Verizon then just flash it manually. The files are available.
Picked up an unlocked Nexus 6 from Best Buy today and it was still on 5.0 out of the box. I don't have my nano sim for it yet but 3 OTA updates later I'm on 5.1.1.
Posted via the Android Central App (Shield Tablet)
Pulled the sim and did a factory reset now on 5.1.1.Seems to work fine on my Verizon sim N6.
I got 5.1.1 on my t-mobile Nexus 6 about a week ago. No noticeable change other than wifi calling, which isn't a big deal to me.
That's ridiculous. If anything, the non-carrier versions will get it first. I have a Play Store N6 and got the OTA update to 5.1 as soon as I booted it.
Btw, since I'm running a custom rom and couldn't get OTA's, I decided to download the flashable zip of 5.1.1 stock android and it is smooth as silk. (unencrypted) I just backed up my custom rom install for when I get bored of using stock. I had to check out 5.1.1 stock though.
Not always. My AT&T Nexus 6 got 5.0.2 before my friend's Nexus 6 from the Play Store. It just depends.
Sent from my Nexus 6 using Tapatalk
If you want to get an update the same time as everyone else then get an iPhone. I don't understand why people get so worked up about updates. I didn't get a nexus for fast updates, I got it for stock android.
Some probably want it to fix issues with the phone that have been present since the 1st purchase. Believe it or not, not everyone has had the same experience you have had with the phone.
so I took my AT&T sim out, put my friend's T-mobile sim in there and the 5.1.1 update popped up, updated it to the LYZ28E build
I tried the same thing, but no success. I previously had to hard reset the device to get up to 5.1. I've got a Motorola Web site purchased 64GB device that has a Verizon SIM.
Keep in mind Google is unifying all of the builds. Lmy47z may be that first unified build. If it is that means any future ota after Lmy47z pushed can be loaded by any nexus on any carrier and some of the population wont be stuck just because of their choice of carrier.
Found this article posted by Pocketables:
Google will unify Nexus 6 builds in future
OTA updates
0 Comments
John Freml March 24, 2015 Android ,
Features, Software Updates
Fans of the
Google Nexus 6
by Motorola
have been quite
perplexed these
past few days,
ever since multiple builds of the same
Android 5.1 update have been appearing. So
far, LMY47D, LMY47E, LMY47I, and LMY47M
have all reared their ugly heads, although
Google has only posted factory images for
the first two.
To make matters more confusing, AT&T and
Sprint users have received LMY47D as an
OTA update, T-Mobile users have received
LMY47M, Verizon is apparently shipping the
device with LMY47E, and international users
have received both LMY47D and LMY47I.
LMY47E appears to have the most updated
radio, although some users are reporting
better radio performance with LMY47E, while
others report worse performance.
However, in spite of this big mess, a little
birdie has tipped me off that Google expects
to have all of these various Nexus 6 builds
unified in a future OTA update, although we
don’t know yet when that will actually occur.
Apparently, Google allowed each carrier to
test slightly different builds on their
networks before approving the update, which
accounts for these differences. Luckily, it
appears that the actual software ROMs are
identical across devices.
So that’s the story. For now, I wouldn’t
worry too much about which version you
choose to flash or which version gets sent
to your device – it will all get sorted out in a
matter of time, and there really aren’t any
earth-shattering differences between them.
Thanks, Charlie!
TaiTheGuy
