6.0 Marshmallow: Verizon Galaxy Note 5
Is it me or did we loose choices on how the lockscreen was? Before we had bubbles and some other things now I cant find it.
But you can change the app shortcuts! That's new!
Verizon Galaxy Note5
Just downloaded it. So far I don't see any major changes. I just hope the battery is better now
Perfect so far!
They added "on tap" for Google Now. If you are on any screen and hold the home key it will give you cool information about what's on that screen. For example if you are texting someone and they mention a restaurant, it will find in on the page and give you reviews and such.
Has anyone found anything else?
With a tiny sample size of just 9 hours, the battery seems to be holding up nicely.
Better than Lollipop for my phone.
Ever since updating my wifi connection is extremely slow!! I'm not sure how to fix it. I have done the "forget network" I've rebooted and restarted nothing is working.
Perfect so far!
Still trying to figure out how the "on tap" works.
I downloaded it around 3pm today. So far it makes the experience much smoother in my opinion.
Having an issue with my lock screen when restarting with fingerprint not working right away. And ontap is pretty neat but I doubt I'll use it much. The WiFi calling will be cool
Has anyone else noticed they fixed the WiFi bug? I noticed now when I have WiFi on, my network data isn't running at the same time. Only WiFi is being used for data instead of both at once. I attached a screenshot of how it used to be (black screen) and how it is now
just hold the home button and it will "read" what ever is on the screen. then you can swipe up and it gives you more. HOlding the home button doesnt go to google now, you have to tap the G at the bottom after tap and hold.
Don't know why all 3 won't attach in one post
I got it now. Thanks
Sorry about the earlier response...just got home and updated and it looks like they removed the option for weather on the lockscreen
Thanks for the update. Kinda sucks, I liked the weather on the lock screen
arcworldwide
