6P Screen Protector
Just installed a Supersheildz tempered glass screen protector. It has all the cutouts, and was a replacement for the one they initially sent in that lacked the cutouts. Quality is good, screen feels much smoother now with the glass on. It is however a tight fit and the power button is a bit tight with the google nexus case on. Overall high marks so far !
My replacement arrives in another day or so, but I went ahead and put on my original one that they shipped missing the cutouts and I have not had any issues with phone calls. I've actually had more than usual.
Will be glad the replacement arrives though as the original one did not adhere well to the lower left corner of the display though it appears centered up pretty well.
I preordered my IntelliGlass screen protector back on 10/26 and now got this email. Probably the same issue with everyone who ordered since then maybe?
"Hello!
If I had to guess, you’re probably wondering where that pre-order of your intelliGLASS HD Nexus 6P order is.
I can confirm our updated and revised intelliGLASS HD Nexus 6P has finished production and shipments will begin soon.
The bad news is that due to an international shipment delay beyond our control, not all of our inbound shipments were received which in turn delayed the shipment of your order.
The good news is that we just heard back that our intelliGLASS Nexus 6P inventory has cleared customs and is on its way to our U.S. warehouse. The second it arrives, shipments will begin shortly thereafter.
I can assure you that we’re doing everything we can do to get your intelliGLASS in your hands as quickly as possible and we stand behind our satisfaction guarantee and lifetime warranty. To help keep you up to date, we've added a page to our site that will updated with the most current information - intelliARMOR.com/nexus6p
Our support team is standing by to answer any of your questions on this and is ready to help.
Adam Webster
intelliARMOR Support Manager
support@intelliARMOR.com"
I live in the States and Zagg told me that their 6P glass screen protector is probably a couple of months off, if you go to one of the Zagg kiosks, Zagg can download a 6P template and make a polyurethane screen protector that is supposedly military grade I will probably do that until their glass one is available.
Please do. I'm curious how you like it
I'll be sure to do so. I've used Zagg Glass, MIME, XtremeGuardz, iVoler, Verizon Glass, etc. as brands for my devices. Some didn't last long due to the cut being poor on devices with 2D glass but all felt good. Keep you updated!
I've heard great things about this screen protector, http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4832223
It should be here on Sunday. Keep you posted! If the quality isn't up to my standards I'll get a refund and go with MIME. Just trying to get one quickly and MIME will take longer and cost more but they're top notch.
Looking forward to your review on it. Never heard of it, but seeing the high% of favorable reviews, sounds like a winner to me :)
anyone get their intelliarmor yet?
Nope...after that email last week saying from Nov 9th, it would be another 4 more days, I presume this week it should come. It better be the schiznit or I will be super pissed! Preordered back on 10/26!
I installed the Yoozon and it wouldn't adhere to the lower right corner, though it's probably my phone and not the protector. I am currently using the Mr. Shield crystal clear cover but it's a massive fingerprint magnet compared to the Yoozon. Both had/have the proper cut outs.
Everyone I hear complain about the protectors not sticking say its the lower right corner. Hm
I also ordered the Yoozon. Hasn't arrived yet, but good to see photos. The packaging and price looks EXACTLY the same as the Pleson, so hopefully both will work well for those that have ordered either of those. Looks like I need to take extra special care on that corner though.
I am using the one that came with the Ringke case (I think it's just an Invisible Shield), and I must say it's quite excellent. Leaves about a 1mm gap around the edge of the screen, that's it (the glass screen protectors usually leave a lot more space). You can also buy 3 or 4 of them for $10.
Screen protectors are extremely hard to get on flawlessly, usually when there's an issue with it it's not the product's fault. I've screwed many of them up in my day.
I just applied my iVoler tempered glass screen protector onto my 6p. I was worried that my Spigen Rugged Armor case was going to be a problem considering how close the screen protector rests near the edges. No problems at all! The screen protector adhered instantly and I pushed out two bubbles at the corners and it looks great. I was worried that it was only $10 from Amazon but I'm glad I took the plunge. I would rate this screen protector at 5/5 stars. Any dust or smudges you see in the picture is not trapped underneath the protector.
Just to be clear, here are the links if anyone wants to go with this combination:
Spigen Rugged Armor
iVoler Tempered Glass Screen Protector
Spigen Rugged Armor
How is the Spigen Rugged case? Mine should be here by the end of the week or early next week.
I'm a big fan of cases that will protect it from small dings and scratches so it fits my needs perfectly. It doesn't add much bulk to the phone so I'm happy with it. Ports are large enough for the power plug and headphones. The volume/power buttons are responsive and I can take screenshot without a problem. I wouldn't expect this case to protect the phone like an Otterbox would which is fine with me. I would buy it again.
BarishYadav
