6P Screen Protector
It's been a week since I ordered the Intelliarmor and still no updates. :| And no I found out they're shipping based on order of purchase.
Is it possible to get this refunded? I'm leaving the country end of this week already and no one is gonna be home to get the item.
Whats a good alternative brand?
I think the bottom cutout is to help those that have tapered corners on their N6P's. Of all the people that have tapered corners, the bottom right seems to be the worst of all. Not 100% though.
I'm using a decent plastic (PET) film protector currently and it is doing well. I can wait.
I agree that the new bottom cutout is to help their protector stick better around that area/bottom corners, but :
a) why is taking so long to ship? I've emailed twice in last 2 days and called once with no explanation
b) why can other screen protector makers NOT have a bottom cutout and adheres fine with no bubbles or lifting?
c) why didn't they email their customers?
I got a refund, no problem*. I just emailed my order receipt into the support email and got a note saying refund is coming.
*I haven't actually seen the money yet, but I got a note saying it's coming ;)
I received and installed the redesigned Supershield TGSP and I really like the final result. Installs easy with good coverage. No halo effect on edges. Feels silky smooth and works perfectly with my 4 cases. Good deal for $7.
So what's the best tgsp?cancelled my intelliARMOR already. Need it shipped tomorrow before I leave the country. Haha
For me it was between the Pleson and the iVoler. Both $7.95. [I went Pleson] iVoler might reach you faster with Prime though, I ordered Pleson yesterday (expecting delivery tomorrow) and 2-day turned into 5, now expected arrival on Monday. Both say "fulfilled by Amazon" so not sure why the lag.
Does anyone know one of the tempered glasses that don't lift in the bottom right corner? I have gone thru 3 ivoler and 1 skinomi (which is amazing a things considered) and all lift up on the bottom right corner. I work for a phone store and the guy who puts mine one does at least 15 a day so the installation is not the issue. The skinomi even stuck fine at first and started raising after. I google and it shows tons of people saying they have that bottom right raise up. Thoughts or ideas anyone?
I just applied my iVoler tempered glass screen protector onto my 6p. I was worried that my Spigen Rugged Armor case was going to be a problem considering how close the screen protector rests near the edges. No problems at all! The screen protector adhered instantly and I pushed out two bubbles at the corners and it looks great. I was worried that it was only $10 from Amazon but I'm glad I took the plunge. I would rate this screen protector at 5/5 stars. Any dust or smudges you see in the picture is not trapped underneath the protector.
Just to be clear, here are the links if anyone wants to go with this combination:
Spigen Rugged Armor
iVoler Tempered Glass Screen Protector
Thanks man, I just ordered this combo via Prime shipping. Both should be here early next week! :)
I took off the Yoozon after it wouldn't adhere and installed the Mr. Sheild which is not glass. Yoozon has since sent me a replacement but after painstakingly installing the Mr. Shield and removing the dust, getting it exactly perfect, I'm not in a rush to remove it and go back to the Yoozon. I'm afraid it was my screen that wasn't perfectly flat, not a defect in the Yoozon, which means I'd remove the Mr. Shield and have the same problem with the Yoozon and have to install another Mr. Shield.
I'm leaving it for now. I will say, the tempered glass Yoozon was much better at repelling fingerprints. The Mr. Shield is a fingerprint magnet.
Same here, except I decided to remove the Mr Shield which took me longer than any other screen protector to get perfect. I decided to end up switching because of the fingerprints. They are so bad on the Mr Shield screen. Anyway ordered the Yoozon glass screen with the updated cutouts and will say its pretty good so far, much better for fingerprints, feels pretty good, and wasn't such a pita to install.
Arg the iVoler won't stay down in the same spot as my Intelliarmor. Lower right corner again!
I am using the iVoler and have the same issue. It leads me to think the 6P comes from the factory with the lower right corner lower than the other corners. Can't explain why, but it looks that way. BTW, the Home button appears lower also. It is not perfect, but I can live with it.
You guys think the front glass panel is created somehow not-flat from the glass OEM? ...or do you think the aluminum housing is somehow pulling the glass downward in the right corner? This is a strange issue, but it's happening enough to look into.
other possibilities:
- screen-protector OEM going short on adhesive in that corner?
- screen protector OEM producing screen protectors that curve upwards?
Nope...after that email last week saying from Nov 9th, it would be another 4 more days, I presume this week it should come. It better be the schiznit or I will be super pissed! Preordered back on 10/26!
Got an email saying my intelliarmor is shipped and I got a tracking number, no info on whats the delivery date yet.
I've been using mr shield's normal screen protector - yesterday, while I was attempting to set my phone down on the passenger's car seat - I instead dropped it on the sharp (emphasis on sharp), metal seat bracket - it was dark and I had pushed the seat all the way back for some reason. it cut/chipped the screen protector and I was certain it had chipped the screen.
Took the screen protector off to find it hadn't penetrated the screen protector all the way - just the surface of it, and the screen itself, in perfect condition.
Maybe in certain cases but my glass protector that I posted above went on flawlessly. So my glass isn't curved.
I have the exact same problem in the exact same place with two different brands. I'm getting an iVoler replacement and am going to try to apply that corner first (somehow). Very frustrating. I don't want to go back to the Zagg type screen protector. The TGSP feels way nicer. Clearer too.
I had Mr sheild on my 2014 moto X and twice the screen protector got scuffs and wore away in the same spot. I threw the last one out and ordered these illumisheild ones and these have been great
Ashok Dharshan
