A long time to charge from the included charger
Have a look at the battery status while it is charging - see if it says Charging (AC) or Charging (USB). If it says USB then it will have switched to a lower power draw mode and take a lot longer to charge. If it does show USB then this might indicate a problem with the charger or the USB cable. Try pushing the USB cable fully into the charger. Try swapping the USB cable to a different one , otherwise a problem charger.
It depends what you put it in. If it goes into a power supply with other things plugged in, the power will be shared. Plug it into a wall by itself and take a look....
As for "don't have it plugged in with other stuff as the power is shared". The Amp rating of a power supply, cable, multi-socket, wall socket etc are just the maximum ratings that these devices can safely supply. If you try to request more power than that then they will usually heat up and possibly burn out.
Therefore a 15amp socket can supply a maximum of 1.8Kw at 120v (wihout going into power factors etc).. The input of a charger is about 0.2A or about 24W at 120v. So you could have about 75 wall chargers plugged into the one socket (barring power loss through the multi sockets) before you might find problems sharing power. This little draw is unlikely to be affected by any regular devices you are sharing the power socket with. You'd already be risking your house burning down before it affected the charger.
I've been using about 3-4 different wall chargers to see which one charges the fastest.
1. Stock LG charger
2. Apple iPhone charger
3. Griffin Micro Powerblock
4. Apple iPad charger
Out of all 4, the iPad charges the fastest for the obvious reasons. But the other 3 vary charging times and I'm not really sure why because they all have the same specs.
Isn't this just a product of the phone/charger going into trickle charge mode after being fully charged? ie, it fully charged to 100% at some point over the night, and once it did, it was on trickle charge until you picked up the phone when you woke up
UrbanPhone
