AC Sideload Wonder Machine for Windows
Status
Not open for further replies.
Everything goes as planned, and then I get this error. Two diag tools said everything was a-okay. Windows 7 32-bit, I have installed Android SDKs on this machine. Using the latest HTC drivers as well.
try deleting all contents of payload folder , restart ACSWM , put the app back in payload folder and try again to install it
if this happens again do the above process again but try a different app a known good one if you can
evry time i try use side loader i get this message
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at AC_SWM.frmDiag.Button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AC_SWM
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Gary/Desktop/source/source/AC_SWM/AC_SWM.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
AC_SWM
CodeBase: file:///C:/Users/Gary/Desktop/source/source/AC_SWM/AC_SWM.exe.
it was not installed correctly , the ACSWM folder should go directly onto the C drive
see post# 16 of this thread and review installation instructions
If you look in your windows explorer the folder should be directly under the C:drive like this
How to install the new version of AmazonApps
I love the Sideload Wonder Machine and generally it works perfect. I downloaded Amazon Apps and many free apps they offer, using the Sideload.
Now Amazon came up with an upgrade to their program. When I try to install it with Sideload, it gives me the following error message:
"Installed Failed - Already Exists".
This is also true while trying to update other AmazonApps downloaded applications.
How do we deal with that?
did you check off the update existing app box?
I'm having trouble getting this to work. I have installed HTC Sync, which is what I think you guys mean when you say "You will also need to install the adb USB driver for your phone." If that's not the case, let me know. Anyways, I'm having trouble when I try to install the .apk: "Could not find a part of the path 'C:\AC_SWM\payload\to_install.apk'". What's going on here?
Edit: I'm on an HTC Inspire
it means either you did not install the ACSWM folder in the proper place, try using the diagnostic tool, if you get a JIT debug message it means you def put it in the wrong place, if you get a message that you are missing a file or folder then somehow you deleted something by accident
I ran the diagnostic and I don't think it was a JIT debug. "When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger...rather than be handled by this dialog box." So if that rules the JIT thing, what's next?
you need to move the ACSWM folder to your c:\ drive , not inside any folders
It is in my C:\ drive. I have another hard drive, and I put in that one just as a test, too. Neither worked.
I've never done a screen share before. What do I need to do?
Alternatively, I could post some screen shots.
Status
opegamani
