AC Sideload Wonder Machine for Windows
Status
Not open for further replies.
I am having the same corrupt(?) zip file problem. I rebooted both computer and modem, still the file is downloading only 66kb. What to do??
Also, will I have to root this inspire in order to use AC Sideloader? It blocks unknown apps.
are you downloading from post 1 or 16?
Just a note, I have tried to use it. I have failed, keep getting the insufficient space error. I even factory reset and still get it. Motorola Backflip 2.1
ok the problem is not the just the phone or the wonder machine its a combination of things. It usually starts with a bad apk and goes down hill from there. So try this, find a couple different apk's.
clean out the payload folder(by deleteing contents) then put the new apk into payload folder , then try to load the apk
if it fails clean out the payload folder, close out the wonder machine, reopen and try the above process again.
try THIS apk,,,, DO NOT USE IT , ITS JUST FOR TESTING PURPOSES
let us know if you can get it to work, if not ill work with you if you are willing to get it to work
dos box problems
Hi the sideloader program was working earlier. No the dos box comes up and hangs with the following error message. daemon not running. daemon started successfully. Then the dos box hangs and a restart will be the only thing to release the dos box.
Try going to task manager>processes>adb.exe>end process
Have you tried rebooting your computer?
also try a different USB port or if you have another USB cable, sounds like either a connection problem or a port conflict of some kind
I meant to post earlier. After posting I skipped a few pages back and read where someone deleted the contents of the payload folder. I did this and it worked, however the reset was needed as well. I am glad to know that the factory reset wasn't in vain....lol.;)
Windows XP?
I think there is a bug that hits some computers running Win XP, and not others. And not my virtual machine build of XP.
DroidXconn has tracked it down, and once we can verify it, a fix will follow shortly.
I tried rebooting my phone and computer.
then the only other thing i can think of is that you have a drivers problem run the connection diagnostic and tell me what you get back
Also what type of phone do you have?
It gets on the diagnostic screen daemon not running. daemon started successfully. This screen will not close if you x it out.
The latest version of the Goodsync is a very corrupt program. I installed it at about 2:30 PM today and it is corrupted. I cannot uninstall this program. I would suggest putting as a sticky because this program is crap.
i dont even know what that is
Status
omgitsjoshitos
