Always On Display not working
I had the same problem with my S8. This worked for me...changing the AOD display settings...always on. Didn't know about the change in settings for Pie.
Ok I used this thread to figure it out but nobody listed a clear way to do it so hopefully this helps... go to AOD settings (turn on and tap for more options) >display mode > always on. Mine was set to "Tap to Show" now it works! Why AOD can be set to sometimes always on display is beyond me lol
my S9+ Always on display stop after installing beta version of One ui. I went crazy. i did my experiments and found a fix. Just uninstall the always on display update.
Hi.
I did the Pie update for S9, Sprint network. The always on display isn't working and the phone no longer "wakes up" for notifications (except Snapchat, go figure). I've looked in the app notification settings and maybe I'm missing something, but it seems like the screen should wake up.
I've restarted the phone, changed themes, done the cache partition wipe. At this point the special features I love aren't there and I'm super frustrated.
Setting>Device care>Battery>Power mode> (select) Optimised
Holy crap people. Learn to use your phone before coming on here and having a hissy fit. All of the problems posted are user errors and ignorance, not Samsung’s or androids or the update. Instead of posting a thread whining, do a quick google search.
^^^Someone's doing a lot of overcompensating for a little something else...
Techman
