Android 12 beta now available.
Status
Not open for further replies.
Yeah , the shortcut maybe I have to get use to it but I like the Android 11 way
Haha, yeah dude Most people do. Googling released an official annual 12 Beta survey via Google Docs. I'm not sure if you saw it, but they're asking what modifications you would make to Android 12 beta 2 if it weren't to go into production right now. Of course, everyone is saying the internet / Wi-Fi quick toggle setting. Other than that, my Pixel 5 on beta 2 is pretty darn stable! What do you think overall?
No haven't seen the survey , for most part I like what I seen with some things like wifi and data toggle in my opinion should be separated
Yep yep absolutely. That's the same sentiment with everyone else. The most part auto-theming material you from the wallpapers, is awesome! We're all waiting also for the Gboard to take the material you auto theming as well.
Yes I agree
Thank you all for your input. I decided to try doing a factory reset with Android 12 Beta 2 being the OS run on my Pixel 5. It worked like a charm. All of my app crashes went away once I did the factory reset. I may just keep it as my main OS on this phone.
Cindy
Glad it worked. That worked for me too. Got rid of any bugs brought over from Android 11.
If I change my wallpaper I have to reboot in order for theming to change with it. Is it the same for you?
Has anyone been able to get GBoard Material You auto-theming to work yet? Just not sure if Google enabled that yet or not...
Cindy
I was having crashes as well even the pixel launcher crashed on me while I was using it! When that happened I had no choice but to do a factory reset and everything worked really good for a couple of days but then apps started crashing again so I went into android web view as many have suggested and turned it off and then re-enabled it and so far so good.
I am so tempted to try this again, trying the factory reset after upgrading to 12, but I'm concerned I'll still have issues with my Pixel Buds 2 losing Google Assistant. I guess I'll watch for my bug report showing as resolved before jumping back in. I am enjoying all your comments, though. Living vicariously through your experiences!
Have you tried to update to Google app beta version your Play Store?
I had the Google app beta when I downloaded Beta 1, then removed that before downloading Beta 2. Neither made a difference
Just out of curiosity, try downloading the beta Google APP again, jus to see what happens. The reason why I'm suggesting that is because that's exactly what worked for me. lol
That sounds cool. I didn't know that was supposed to be a thing. I haven't heard anything about it and various tech sites that are showing everything on beta-12 have not even mentioned it so perhaps it's coming later?
Status
Jayarealways
