Android 12 beta now available.
Status
Not open for further replies.
Yeah , okay. Fair enough I got you. By the way, I see you have four options in your drop down notification shade. What screen size with you have your phone display settings at? I've tried the higher settings myself and that's why I noticed that.
Double swipe down shows a lot more. Display and Font size set at large.
Until the pig ugly pink showed up I couldn't have cared less about this feature. I consider it aesthetic fluff. Now I have to look at it every time I look at my phone. //uploads.tapatalk-cdn.com/20210707/5132f8613fd8067ce200746b8b1832cd.jpg
I actually like that colour. I have vomit yellow
See, in my opinion, the colors are still pretty cool looking. It adds a splash of color to the OS which it desperately needed.
I agree I like the colour option, just not particularly the shade of yellow they gave me. Pastel yellow would have been fine.
I'm more interested right now in functionality (Assistant not performing all actions in routines for example) vs aesthetics.
It would be nice if a puke inducing color is chosen it could be overridden to a more pleasing and less visually offensive color or just turned off all together.
This.
I'm very sorry to hear these issues. I haven't had any issues with my Google Assistant at all. Granted, I don't have any routines setup, but for all of my commands I give it (turn on Wi-fi, play music, etc) it works absolutely fine.
You're funny... I'll certainly agree with you on that. I mean the reddish color is a little to light in my opinion. But overall, the OS NEEDED some colors, and customization options for sure.
You didn't try my request from earlier on. The issue is independent of routines since it is a stand alone issue. It just so happens to also be a part of some of my routines as well. This seems to be the only Assistant issue present at this time.
Ah, okay got you. Very interesting issue Sorry to hear that you're having that. Hopefully in beta 3, it'll be fixed.
The only real problem I have using the assistant is it sometimes won’t work from the Lock Screen even tho I have that option enabled.
Hit and miss, about 25% of the time it says I need to unlock my phone first. Annoying when in bed and phone is not within reach on charger.
Yep yep, I get that same exact Google Assistant issue. It's not even that much of an issue for me.
That would be annoying
I have the same issue. It would help if everyone who experiences this issue send in a bug report. It would make a bigger impact than one or two reports.
All of the major issues that I've experienced, I have reported. However, I haven't reported this one just because it was a major problem to me.
I know that is your philosophy.
Well I feel any issue big or small should be reported. It takes a minute and could be a big help to get the issues resolved for everyone. After all that is what beta testing is all about, not just being at the head of the line with the latest and greatest.
Status
mersy78
