Android 6.0 Marshmallow and USB Ethernet
bernieplug
We're seeing USB Ethernet devices no longer working after upgrade to Android 6.0 Marshmallow.
Has anyone had a successful experience? What USB Ethernet chipsets?
Anyone else also seeing this problem?
Thanks!
I have used plugable USB-RJ45 ethernet adapter chipset AX88772, with moto G, moto X play, moto XStyle android 5.1
now updating to 6.0, I´ll tell you the results
perfectly working!!! new simbol <...> in status bar, to indicate ethernet is active
Great that it works for you.
I have the adapter and a Moto G 2nd Generation, but have not gotten it to work so far.
Did you have to do anything with it? Just plug it into ethernet and go?
Not sure if my phone has successfully installed android 6 or is still using 5.
Thanks for any guidance. Very stoked to have this work.
Momo
fistyjone
