Android Device Manager arrives
You have to have gps and Google location services enabled for it to locate the device.
AT&T HTC One MoDaCo.Switch Beta 8
Nexus 7 2013 Unlocked Root + TWRP
Chromecast
False...I simply use Google location services and it finds mine every time. Also, if you send the format device signal, and the phone is off, as soon as the phone turns on, it formats it. I did it on mine. Same with the ring function for a wireless tab. I was in a non-wifi area, selected locate and ring, and soon as I got to wifi it rang, and Google now located it.
This sounds better :)
Still don't have the manager on my devices :(
I manually updated the Google Play Services (apk) and now it's here :D
Didn't ring yet though (I sent request to ring) :confused:
better than an app they need to make a website available for it. the idea is that you can locate your phone from any computer or phone connected to the internet.
They have a website u can go to on any phone or computer.
Sent from my T-Mobile LG Escape using Tapatalk 2
Manually installed the latest Google Play Services (apk), which includes the Manager. Now it appears.
I sent a ring command to my tablet and nothing happened...Rebooted it twice and nothing...Then I remembered I wasn't connected to WiFi...I walked into my house in the middle of the night and the damn thing connected to WiFi before I got a light turned on and scared the hell out of me for a split second....It definitely works...
For those not sure still how to connect, just log into Google, or Google Play and you can find, ring, or format your devices through there.
My Nexus 10 IS connected to WiFi though....
Sent from my Nexus 10 using AC Forums mobile app
kctraci1
