Any suggestion on fixing these issues....Help
The *228 and #2 may work for call issue....
Also LP still has issues, I installed the latest update and device was freezing and rebooting on a regular, went back to AWD and haven't had a hiccup.
You are not using any call blocker apps because the description you are giving is what mine does when my Call Blocker app is active, which is normal.
Yes I am! But it only does it sometimes.
Hey can hear me and I can't hear them. It does it even when thr call block app is not active.
Which Call Blocker app are you using, I use Call Blocker Elite? I had issues with a number of others I tried, maybe this is your case.
Ok, I will have to repeat.... I do not use (nor have I ever used) LP. Nor do/did I ever use a call blocker app. They are NOT what is causing this issue. *228 also does not fix this problem. It is software-related, and a reboot will temporarily fix it -- until it happens again, at some random point in time.
Before it happened to me last time, I was playing some music... so not sure whether that is a contributing factor. Anyone who actually had this happen: were you playing music at some point before it happened perhaps??
When it happened to me, only once they could hear me but I couldn't hear them. The other times, neither end could hear the other. Whatever this problem is, it is VERY flakey!
It has force closed 6 times since my last post!! It has to be LPP I will uninstall and see what happens. Does ADW EX have the sliding dock that's what comes in handy the most for me. I have ADW on my phone but didn't want to purchase another launcher!
It does not have a sliding dock but it has a hidden dock that can be accessed but a finger swipe. I use to be a dedicated LLP user until ADW EX was released , I update my version of LLP every now or then to see if my opinion has changed but I always end up going back to ADW...
motoJunkie1
