Any suggestions for a case or cover for the prime?
Made myself one using felt and padding. Velcro closure and elastic band stylus holder.
Sent from my SPH-D710 using Tapatalk
I am thinking about this one. There are a couple other manufacturers that are almost identical. I am getting the dock also. With this it looks like u can dock it without taking the cover completely off. The cover would just fold back behind the tab.
Sent from my Evo 3D on Tapatalk - - BAM, that just happened.
So this is just something I discovered whilst navigating the world wide web. Something to be privy of in case you were interested in this particular item. Of course I am referring to the Verteks and Vipertek slim cases for the Prime. These two listings are indeed identical. Not only in thought, word, and deed, but ACTUALLY the SAME product. Quite a price difference. Check out the links for yourself and notice the pictures are the same and the manufacturer is eerily similar also... things that make you go hmmmm. I'm not sayin, I'm just sayin.
http://www.amazon.com/VIPERTEK-Transformer-Prime-TF201-Black/dp/B006OZTNIK
http://www.amazon.com/VERTEKS-Transformer-10-1-Inch-Multi-Angle-Slim-Fit/dp/B006OJ68AM/ref=sr_1_2?ie=UTF8&qid=1325204136&sr=8-2
Your observations are absolutely correct - I came to the same conclusion with one addition... You can add rooCASE to the list of copies. I have the rooCASE for my OG Transformer and I liked it so much that I ordered the Vipertek version for my Prime. I am also trying the "thin" case from Vertek as well to evaluate. I hopefully I have the chance to do quick review when they arrive.
I just found one of the tf101 tight black covers in Best Buy - they have nothing else. Since the Prime is thinner, slighter in length and a little taller, and this one is somewhat tight on the original, I am hoping this will work, or at least do for protection until there are choices.
Anyone try one of these??
**UPDATE: Moko seams just popped on the top left corner near the volume buttons. Only been using 4 days :-(
Sent from my Transformer Prime TF201 using Tapatalk
I just got the MoKo yesterday and so far it's working out. Fit is very nice but I don't like the fact that when you flip the cover back it won't stick unless you fold it up into stand mode. Not sure if others will fold back flat? I have a kindle with a case which flips all the way back and has a string to hold it in place.
Help me out here. Are you guys using these sleeves as a protection from drops and scratches or for travelling convenience? This is my first tablet and I'm not sure what I need from a protection standpoint.
I purchased this one mostly for traveling convenience:
Amazon.com: Case Logic PLS Neoprene Laptop Sleeve: Electronics
It is a good fit with the keyboard dock attached, maybe just a tiny bit looser then it could be but not bad by any means. I wanted something I could put the Prime in, throw in my luggage and not worry about something scraping up against it and putting a big gouge in the finish.
I pre-ordered the Verteks case when it was on sale for $9.95 (plus $4.99 S&H), received it this weekend. So far so good. It should work for me until I get my dock.
Just got my Prime, put it in the Asus tf101 black case, just like the Ipad case, very thin, somewhat stretchy, it fits but all the cutouts are wrong - the power button under a closed area.
Now I could cut it out, but for $40, I'm not hacking, so back to shopping and returning this. Bummer, I want
a thin, to match the size case.
Maxyguy666
