Anyone else receive OTA update for the AT&T Samsung Galaxy S7 Edge?
Re: Anyone else receive OTA update for the AT&T Samsung Galaxy S7 Edge?
If anyone cares it looks like they enabled the FM radio with this update as they did with the Tmob update as well. Downloading NextRadio and plugging in your headphones makes your phone an FM radio.
How can I get the update if I have an AT&T S7 edge on Cricket?
I'm on Cricket as well. I bought a GoPhone sim and when I want AT&T updates, I just insert the sim and connect to Wi-Fi. Works every time and I get my updates. Same on both my LG G3 and the LG G4 when I had them. It's a great investment and doesn't cost you anything other than your time swapping sim cards to do the updates.
Still no update here. Doesn't it matter if I unlocked the phone?
Do you not have to activate it or anything, just pop it in and connect to wifi? That simple?
Nope. I popped it in. Connected to wi-fi and it recognizes the AT&T branding. I get all of the updates. So, in essence, I just paid the price of the sim. That was it. I heard about it on another thread in the LG forums a while back when I wasn't getting updates. Resolved all of my update issues.
Cool thanks for the info, getting one today and gonna try it out.
Definitely let me know how it works out for you.
Got the sim last night and popped it in and checked for update, still said up to date. Left it in overnight hoping it would try and pick it up but it didn't. Will try again tonight after my 24 hrs is up and leave the sim in longer before checking
When you first power the phone on, do you get an AT&T logo in the upper left hand corner of the screen? This part is important because the means it identifies with the AT&T network. If not, you might need to activate a plan (albeit the most minimum allowed for a smart phone). That would be the only thing else I can think of. Again, I have never paid a cent other than the initial purchase, but mine came with a basic plan, so maybe that's the difference?
Yea it shows at&t in the corner. I might even try to re-enable all the rest of the at&t bloatware and try again tonight from an at&t wifi spot
No such luck again last night. It just won't pull the update
As a former AT&T Note 5 owner (which I believe still doesn't have Marshmallow) I'm shocked. That phone went from the October patch to March patch. It's one of the reasons I couldn't do the S7e
Apparently, I'm not getting this update. Has everyone gotten this update or are others still not getting it pushed to there phone? I have checked everyday since the update was announced.
Winnix
