ApeX 1.3.1 on Droid X!
Am I the only one having an issue with their youtube app after the update? Everytime I try to watch a video it says "there was a problem while playing." This hasn't started happening until I downloaded this rom.
Other than this minor issue I LOVE everything about this rom. I'm hoping this can be solved so I can continue enjoying it. But as I asked before..am i the only one having this issue?
(Nope, none here. YouTube works great!)
FabDroid Wiki...... I tried this suggestion found here and have noticed some positive scrolling action.
System Preferences: Scrollable widget support - uncheck this if you're not using scrollable widgets for a tiny performance boost
Suggestions - FabDroid Wiki
I don't use adw :( long time launcherpro user since it came out.
Sent from my DROIDX using Tapatalk
Reactions: victormolina15
Actually I found that with my device running ApeX, it functions smoother and better with ADW than LP+. I was wanting to switch back to LP+ since I paid for it but after using it for a week and switching back to ADW, it seems better to me. Now, when I was running stock, LP+ was better than ADW, but something is much different with how the phone runs with ApeX installed that works well with ADW.
Just my opinion.
Just my opinion.
Ok you sold me. Ill try it out for a few. Ok already loving the theme packs!
Theme packs, ha ok I think I read about them.
Guess I'm just hardcore LP+ tho :p..ha
Sent using TaPaTaLk
Haha, I wasn't tryint to sell anyone on anything, just giving input. Let us know how you like ADW as opposed to LP+.
Sent using TaPaTaLk
I used to be, but with ApeX I like ADW better. If I'm running stock, then LP+ is what I use.
Any ideas when apeX themes are supposed to drop?
DXmeatclaws via talkatap
Word. Bring on the themes!
yeah I tried out the orange theme from rom manager and wasn't 100% a fan. Just orange isn't really my color, but I am waiting for some awesome themes!
.....ok I got curious and got ADW to test out to , hmmmm ha got to get use to the settings first, they dont set the same haha ;) so far so good tho from the settings I tweaked I havent done the add ons yet , heard there was a popup gesture like LP+ has but havent found it yet
Popup gesture? Do explain, I might be able to find out.
On LP+ when you long press on the app you have set on your dock a pop up window appears and you can set that app to a certain gesture for example:
app to set gesture to is SmS : long press on sms(icon on LP dock)
a pop up window shows gesture:choose gesture you want they are . unread sms,,,, missed phone call,,,,last used apps,, browser bookmarks
On this app of course I would choose unread sms, then a lil pop up appears over that icon whenever I get an sms if I swap over the indicated number , can go right to sms box from there .
I am just not searching correctly for the adw one I think,, because someone said there is one for .98 somewhere in the market :D ha
Ah, I wouldn't know about the gesture thing, I dont use it. I'm just fine with manually tapping on things to get to where I'm going.
till adw adds a calendar and social widget, i cant bear to switch
I've found that all of the social widgets made suck, period. I just resort to using either the Facebook app or accessing the site via the browser. And I love Smooth Calendar, much better than ones I've used in the past.
Ok i have a question why is it that when i click the home button on my dX that i get the option for adw and setup?
NEVERMIND i just hadd to select setup then done adding accounts.
harristn
