Apps on SD card moving back to device after update
After reading many of the posts in this thread I would like to add my 2 cents worth and correct some inaccurate info that has been posted. First the issue is not new with the Marshmallow update, it existed in Lolllipop and Kit Kat. and currently should be most prevalent on Samsung devices. I say that because although Samsung has brought back the ability to use an SD card with the S7s & Note 7S they have not made them compatible with a new Marshmallow feature called "adoptable storage" , meaning you can insert an SDcard and select this feature and it basically makes the SD card part of the Internal storage so then this would be a non-issue if handled right. In fact most of the reviews of the m\newer Samsung phones have taken issue with them about not allowing the "adoptable storage" feature to be used. Personally I agree with Samsung as I want my SD Card to be removable so I can transfer it to another device which kind of goes bye bye if you use adoptable storage. That being the case you are left with 2 solutions to this problem, one has already been addressed, i.e. get a phone with enough internal storage that you don't need to move apps to the SD card. This is simple with the new S7 & Note 7 as they have 64GB internal storage which should be enough for most users. For those of us with phones that have limited amounts of Internal Storage I would recommend using an app called All In One Toolbox. It does quite a few useful things for your phone including semi automating the process of moving the apps back to the SD Card. While not perfect it does make the task easier. I have used this app for 2 years and it is wonderful , does not take up a lot of space or use copious amounts of your battery power unlike some similar apps like Clean Master which has been known to eat batteries alive on some phones. FYI I do tech support for smartphones for a major carrier for a living. Also while I do not work for Samsung I will admit I am a huge fan of their high end devices in large part because they build into their Android OS version handy options like a great file manager app, ability to create your own call auto reject list, and also convert any MP3 file on your phone to a ringtone without having to download any 3rd party apps. Also the new s7s and Note 7s have the best camera around and being able to insert up to a 256GB SD Card in them you can use iot to your hearts content.
I just installed All in One Toolbox and can't find an app manager or other tool there to transfer the apps back to sd card.
I am using s7 edge... was in a rush when I bought it and ended up with only 32 gigs memory. So I'm running out of memory often. It lets me know when I can't install a new app.
It's soooo frustrating and time consuming!
Maybe there is a tool to help doing the transfer faster on All in One but I can't find it. Maybe you could help me?
Agree, but S5 came with only 16GB memory (for users it is less than 10GB) so we users should have given some privileges. It is really annoying I have reset my phone so many times in since I get it. After couple of months I am out of memory and can not do anything.
Thanks for the tip to download All-In-One Toolbox. I downloaded it, went to "Toolbox" (top row on lower right) then clicked "app2sd".
It found the apps that I could move to my SD card but when I clicked "Move Selected" I got a dialog box that said "This feature is not available on your device" and then it sent me to Application Manager and I had to do the whole dang process manually anyway. :mad:
Regarding this thread, there is another issue. I just today have put my old SD card on. I had no choice, I culled a bunch of apps and still had only 1.3GB left.
I downloaded AppMgr III and launched it. Out of a hundred apps I installed, I was shocked to find only 16 could be moved. And only a few of those 16 could be moved without widget support and other functions.
I swear it seems as time progresses, there are fewer apps that can be moved to SD. This is probably deliberate I suspect as Google would be discouraging SD support.
This auto move back to internal from SD on update is still very much a problem on my 32gb S7 Edge running Marshmallow (6.0.1). Having abandoned a 128gb iPhone 6 to convert to Android, I find this incredibly frustrating!
This looks like it's been a recurring problem for years on several versions of Android so why aren't Google/Samsung offering a permanent fix for this? Thought Apple were a bent corporate because they refuse to fix their phones but looks like Google/Samsung are not much better!
It's due to the way they're written. Since apps were never supposed to be moved to the SD card, fewer and fewer developers are worrying about it.
Preinstalled apps can't be moved to SD card. Lack of memory is because of preinstalled crap. For example: Samsung in new models is installing apps from Microsoft and I think they use over 1 GB of internal storage. Normally you could move them to SD, but because they are built into the ROM everyone lacks memory.
I have this issue on Sony Xperia Z3 Tablet Compact. It doesn't happen on S4 (5.0.1), Note 4 (6.0.1) and I need to test A5 2016.
When an app is updated, it installs a new version of the app - and apps install to internal storage by default. That's normal. (Remember, Android was never designed to run apps from the SD card.)
It doesn't have to install to the internal storage, because in previous android versions it did not move the apps. Developers changed it, need to change it back. It's also a problem on lg tab 8.3 not just Samsung
I have the same problem on my LG Spirit 4G LTE which runs Android v6 (Marshmallow) and comes with only 8Gb of internal storage. I didn't fancy formatting the 32Gb microSD card as internal memory, so I've also downloaded All-In-One Toolbox and got the same msg when I tried to use the app2sd tool. But at least I now have a tool that shows me which apps can be moved once they're updated and am taken straight to the screen for moving each app one at a time. So thanks to everyone for their contributions on this forum, I've learnt a lot about my Android OS and will continue to use AOT to get round this annoying flaw. Unless Google & the developers sort this one out I guess I'll have to go for a better phone with more internal storage when I'm due for an upgrade!
Well, maybe they should get redesigned. I'm tired of having to move app after app back on my SD card and storage senselessly being wasted.
Welcome to Android Central! You can certainly give that feedback to Google by using the Feedback option in your system settings. Obviously, they can't respond to every single bit of feedback, but at least you have a way of expressing your ideas to them.
Hi, just thought id jump in to say that apps on sd card actually now stay put!! Dont ask me why , but i dont now have to fanny about moving them when they update, motorola g2 second gen.
Still have this issue on my tablet though.
This is clearly a piece of planned obsolescence by android. constantly forcing apps back to internal memory so your phone slows down and people upgrade their phones. there is no reason that the apps could not be updated and left on the SD card. we should not tolerate this as consumers and i would like to find the right place to raise this issue get it changed. we have paid for these devices and should they should not be interfered with in this way to reduce performance and force us to upgrade when we otherwise wouldnt have to!
See response in your other thread: https://forums.androidcentral.com/a...internal-storage-after-upate.html#post6115390
AIO Toolbox Does not work in batch mode on my S5 w/6.0.1 os. Msg says feature not supported on this device.
maryhurst515
