Archived: [ROM[2.3.7]LeWa OS! 3.2.2
Ohhh right. The old link didn't work because I deleted the file. I then posted the APN edit one.
Gannon told me to try the Optimus One port, because they have more working. Maybe ill try it once I get home if everything goes well. :P
I'm not done yet ;)
download this file: libandroid_runtime.so
and place it in the /system/lib of the ROM i just gave you.
Any possibility that this file still exists? Estabien might have solved an issue with the systemUI.apk with the icons not being named correctly to work on the statusbar, and we think that might be the reason it wouldn't boot on the Slider. Not sure if the issue was that, but this missing file might be needed to boot up the rom.
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
Go check with Estabein right now. I got him a nice guide and he should be porting it fairly soon
Thank you so much! I'm gonna try my very best to support the development of this rom.
Well keep up with CuriousNoob. He might just take off :). Like I've said multiple times, he is now the owner of this ROM and I will still help, but feature and bug requests will have to go to him from now on.
Awesome almost everything works, camera takes pic only, no video jet, most apps install!! If they don't then I place them in system/app ;) is there any way on geting mms to work! I really just need this to work, well the music app too but all in time :) thanks noob(curiousnoob)!!!
Reactions: CuriousNoob
Thanks, But I found something very interesting I can send pic yes MMS but..........I cannot receive MMS,:( the trick for me is to send the pic,then forward the pic, and they receive the message :)
Has anyone tried installing Whatsapp? Whenever I attempt to install it it says that a shared library is missing.
Somebody try to send MMS and receive 9999999999 answer with some characters??? And if you forward some MMS they receive the message...
^^_ I just tryed it and it install normal!! Have you try rebooting your phone
Sorry Badboytoast, I meant to edit that post and say I found a fix. It was due to Google Maps not having proper permissions. I also found out that I didn't have the latest build after going through the thread to find out whether or not anyone else was having issues with MMS. Lack of MMS was a real deal breaker for me, it sucked that I only found out about the lack of MMS only after I had gotten Lewa to look just the way i wanted it to look. :'(
Once MMS is fixed I'll be back on the Lewa Train!
pratikkumarBB
