Are there any tempered glass screen protectors that actually stick properly?
Received my Base screen protector today. Applying it was super simple. Base provides a template jig you put over the phone. The screen protector fits perfectly in the jig. Pulled off the jig and used the lint free cloth to press along all of the edges. No problem with the case and the protector. Time will tell if this stays sealed. Really like the feel of the smooth glass. No issues with sensitivity either. I've applied many screen protectors and I have to say, Base is the easiest and quickest screen protector I've ever applied. Ordered it from Power Peak Products.
https://www.powerpeakproducts.com/base-tempered-glass-screen-protector-for-galaxy-note-8/
I have the Zagg glass and its HORRID. Way too much glare.
You know that 'seal' you get when you install a flat screen protector on a flat screen? Like how the glass looks 'cloudy' until the screen protector adheres to the screen? Well its like that over the WHOLE screen bc the tempered glass doesn't seal to the screen of the phone. Its not a good design but I feel its the best they can do for now bc of the way the edges are it would have to be a precision designed for each screen.
We installed the Zagg glass on my wife's phone and the screen sensitivity went to crap. I don't see how people keep recommending that thing!
Still Loving this film. It's holding up really well even with it not vertically lined up and peeling bc of the case. I recommend the spigen film for $9 on Amazon just bc it comes in a 2 pack!
I just installed the i-blason tempered glass.
So far so good, but I also have a case with a front perimeter covering which may help keep the screen protector in place.
Had two white stones delivered and both had induced air bubbles on installation, third and final attempt on its way. After that I guess its onto Zagg next.....
I would assume any air bubbles are probably particles that fly in the air before you can drop the glass down maybe try to make sure you are in a dust-free environment
I don't know guys & gals - AT&T put a Zagg Invisible Shield Glass Curve on mine when I picked it up at the store on the 15th and it's stayed stuck, the sensitivity is great, it's ultra clear, better than the BodyGuardz HD Contour thing I had on my Note 7 for sure! Sorry so many folks are having trouble with it... I like it!
I had the Zagg invisi-shield (I believe it's called) glass protector installed on mine at AT&T before I even touched the phone & it's great! No lifting at all on the edges or anywhere else.
I installed the Zizo glass screen protector that was included with the case. It doesn't wrap too far around the edges and it was an easy install as it has full adhesive. Works fine with pen, connectivity is good, fingerprints are the biggest problem and those can be wiped off.
I have no issues with the Zagg curved. You can watch the installation video on their website if you want an idea of how it installs.
Zagg pops up from the middle when you add a case. Stays on, but you can see where it has separted from the N8 screen.
Tfunz
