Are there any tempered glass screen protectors that actually stick properly?
This is always a on going discussion nothing really works well with curved screens for one reason or another
Just installed Whitestone. I thought the install was much easier than expected. I watched the video twice and read the instructions well before starting. I also had everything laid out as needed and within easier reach. Install was pretty fast and easy. No bubbles (yet) or dust under protector. Responsiveness is just as if I were using the regular display glass (that was my gripe with other glass protectors). Seems to work fine with my Spigen Liquid Air case. That said, I'm planning to leave the case off for a while just so the protector has more opportunity to fully cure and lay on the screen without disruption. Ultimately, my goal is to use a skin on the back and go without a case. My only complaint is the smell of the adhesive, which is pretty strong even now while using the phone. I assume that will dissipate soon. I'll update this should I encounter any bubbles or other issues in the next days.
I have the Zagg glass and its HORRID. Way too much glare.
You know that 'seal' you get when you install a flat screen protector on a flat screen? Like how the glass looks 'cloudy' until the screen protector adheres to the screen? Well its like that over the WHOLE screen bc the tempered glass doesn't seal to the screen of the phone. Its not a good design but I feel its the best they can do for now bc of the way the edges are it would have to be a precision designed for each screen.
I have the Zagg Glass and have no issues. Can't tell that there's a protector on the phone!
Same here Whitestone and Liquor Air Armor case.... The fit is nearly perfect between the two. I can tell though if your installation was shifted ever-so-slightly you may have a chance to have issues but in that case I will just suggest filing down the edge or whatever Edge is closest to the glass. Luckily mine seems to be spot on the corners of my case but right against the glass and it is really a awesome combo. I know in the videos I think he said he did not recommend this case with the screen protector because if the case were to flex it may start pushing the glass but this case is pretty Rock Solid and doesn't move even when squeezing the sides and corners..... So far at least
OK, so I just had best buy put on a zagg invisiHD film protector on my phone and it's a world of difference. I doubt it will last but that's ok bc it's on them. They said that since they put it on that they will put a new one on for free. Otherwise I may just have to forgo a screen protector because I'm not totally sold on a expensive Whitestone dome just yet.
I heard that the Whitestone dome glue is not very strong if any Casing were to push it up after 1 day it will form a whole strip of air bubble
Here's a few quick pics of what mine ended up looking like.
And another one...
Sorry for the bad lighting and angles. I took it and posting with my S7E on the AC app
Hi everyone. :)
I have tried countless tempered glass screen protectors on my note 8 but none of them stick to the screen properly all the way around the edges.
Just wondering if anyone here with a note 8 has actually managed to find a glass screen protector that they are 100% happy with?
Cheers thanks. :)
My zagg w lifetime replacement is good. I was super ocd about pressing it down firmly so the adhesive would stick. I put something heavy on it and laid it upside down for a couple hours to help it more. A little bit of hair /lint gets attached to it a little but meh. This phone NEEDS impact protection bad. I dropped my s8 plus in a uag case face down and cracked it all to hell.
I installed White stone Dome, and installation was pretty easy!! I have Spigen Hybrid Ultra S case on it, and Love Love Love it!! Now if I could only find something that works for my Hubby's Otterbox Defender! Anyone heard anything that works with the Otterbox Defender?
I'm using a nano liquid wipe on glass protector. I'm not going to lie. The stuff is pretty impressive. I hate scratches on my screen. And I hate plastic screen protectors. I always get scratches on my screens. Normally within a week. The first time I used it was on my S8+ and I was amazed that I have zero scratches on the front or back. So I put it on my note. So far so good. Really thought it was a scam. I'm a become a believer. And no case. I hate bulk. I'm not listing a brand because I'm not trying to sell their products. Just some input.
I'm using the zagg glass curve with the otterbox defender and it's perfect.
I had a Zagg on my Note 4, and it was great. Bought one for my new Note 8, and not so much. Makes the screen lag, and miss keyboard tapps. Got it 4 days ago on Thursday, and Friday night cracked it on the side. Three more days later and it has already popped off. As much as I want to (and feel I should be) run one I'm thinking about just keeping it naked. The screen just performs so much better without it.
I did the same thing had it on my S7edge and now on my note 8 also had it on my note 7 had it on S7edge for over a year not marks of any kind screen look like new
I did the same thing i had liquid armor put on my S7edge and now on my note 8 also had it on my note 7 had it on S7edge for over a year not marks of any kind screen look like new
Here are some better images.
TR - Top Right
TL - Top Left
BR - Bottom Right
BL - Bottom Left
sellhousefastmke
