Are there any tempered glass screen protectors that actually stick properly?
I can't be doing with a tempered glass protector. However hard I try to install correctly, there always remains an input latency between the two layers of glass - it does my head in. I think I'm going to go naked and just be careful.
I am in the minority here but despite the not so good reviews on Amazon for the Poetic tempered glass I have one on my Note 8 as well as my wife's. We have zero issues. It fits well, does not have sensitivity issues, no lifting, and it fits our Spigen cases. I believe the only drawback is that the glass does not resist finger prints as well as the actual Samsung Gorilla Glass but it is not bad. It wipes clean easily. Not sure how these companies utilize quality control for these tempered glass but we must have been lucky.
try that one I posted #8...haven't noticed any latency issues with it...
Try something that has full adhesive in the middle. It will not have any sensitivity issues.
OK, so I got my zagg temp glass screen protector and it was applied perfectly and fits well with no lifting issues.
Problem is that I feel like there's more glare or a "haze" since there is no adhesive. Is this correct?
2nd problem is that for matrix looking effect. Is that the samsung screen or my screen protector?
3rd question is are the film screen protectors still a good option or is the Whitestone dome the got to now?
I've been lurking here the past few weeks and decided to give the Whitestone one a try. I never install myself, I have terrible luck but I did this just fine, and the Verizon folks were pretty impressed with it and asked me the name (ran in to look for a Mophie power bank - we moved into our home two months ago, and I can't find the one I had for anything!).
So - I'm sold on Whitestone!
OMG!!!! WOW... So many people have posted! Too many to thank individually so I'll say a massive THANK YOU ALL! I now need to find a few spare moments to read all your posts. Thanks again... i really appreciate all your posts. :)
mind if I ask what case you're using?
After so many good reviews and recommendations, I went ahead and purchased the WhiteStone Done glass screen protector for my Note8! Once I get it in the mail along with my Note, I will let you all know how it goes!
Got the zagg. Installation went flawless, but yeah it does showore glare / slight haziness and touch response is also slightly reduced in some areas, like the lower right corner in my case. I'll keep it for now but am considering getting the Whitestone Dome when I get back from the business trip I'm about to go on.
The more I use it the worse it gets. I'm debating just taking it off. Do you think AT%T would refund me for that?
I heard the Whitestone dome glue never hardens. Is that true after a year to 2? What about removing it and what about dirt? And would a film be the o my other option?
Well, the glue is cured with the UV light, but it doesn't get "hard" persay. It gets more sticky and tacky than anything.
I heard that the Whitestone dome glue is not very strong if any Casing were to push it up after 1 day it will form a whole strip of air bubble
It's not glass. Which I prefer but I got the spigen one regular one the wet application.
At first I was leery. It went on nice but had a couple bubbles and streaks. But after 48 hrs it is clear and looks great. It feels nice also. If anyone does find a good tempered glass one I'll switch. Until then the spigen one works great.
Zagg has a glass one. Saw one yesterday installed and thought it looked great.
I had a small issue with mine, it started to lift the corners almost as soon as I put the case on to test fit it. I was able to push the bubbles out without issues. I'll try to take a pic and post it when I get home later.
Tigerchota
