Battery charge at 99%
swkwong
I just purchased the SG Tab 7+ 16GB Wi-Fi and charged it to 100% right out of the box. I also loaded a battery charging app that tells me when the battery is completely charged i.e. past trickle charge. However, once I pull the charging plug from the unit, the battery level immediately drops to 99%. This is the second unit as the first unit also did the same.
Is the normal for this unit?
Thanks,
Simon
I've experienced the same thing.
Also, many users on other forums are reporting the same issue so it could be common amongst the model and the battery.
Sounds like you need to bump charge it.
Charge it up (powered on) until it says it's finished.
Unplug it, and turn off the device
Plug it back in to charge (powered off) again, until it says it's finished. And it will continue to charge now.
Now unplug and turn it back on.
Plug the charger back in (powered on) and charge until it says it's finished.
Keep doing this until when you have it powered on, it says 100%.
IamHg
