Battery Drain Issue from Exchange Services Data
And the issue just kept on happening. So I guess I'm going CM12, unless I find a good alternative email client
So I tried the above suggestion and the issue stopped for a day or 2, then it returned. I went through the process again and the same behaviour occurred. I only have the "Sync calendar" enabled, yet the "Email sync" would go nuts, constantly showing a flickering "busy" image.
This morning I checked under the "Settings->Accounts->Exchange->Account Settings->[my exchange account]->Folder sync settings" and found that the Inbox folder's "Sync this folder" was enabled, even though I had disabled the "Sync Email" setting. Now I hope that the Calendar isn't tied to the Inbox in some way, leaving my without a way to sync the calendar.
If this doesn't solve the problem, I'm flashing a different ROM!
I am having this issue with my Samsung S5 on Lollipop 5.0. Exchange worked flawlessly on 4.4.4, but as soon as I upgraded to 5.0, Exchange is in a constant sync when in "PUSH" mode. I have been using Exchange and Android for years without issue on multiple phones, but as soon as I went to 5.0 this problem popped up. I have tried all of the suggestions given on this thread, but the only thing that works is changing the sync settings to any time interval other than "PUSH".
I find it hard to believe this is a hardware issue as the phone was working just fine on 4.4.x and my update interval has always been set to "PUSH" on multiple accounts. I hope this gets fixed in the 5.1 update.
I realise if I change my wall paper non animated. It seen like improve.
Really? Your wallpaper effects your Exchange service?
I don't see how that's possible, but in any case I'm not running any of that fluff on this phone.
re: demonashes, 1000 times THANK YOU!!!
Because of big battery drainig, when sync was on, I cried almost 2 months after upgrade on Lolipop, and today the problem is solved thanks to your instructions. In this moment: WiFi on, Sync on, Battery 79% and before 40 minutes was 79%, I just can´t believe... :)
If you have folders setup in your inbox you should look at the sync settings for each individual folder as well. My work email regular inbox was set to 15 minutes during peak time and 4 hours off peak. Most of my folders were set to push somehow. Fixing that made a pretty sizable difference for me.
Hey guys! I wanted to share a good news! I came across this thread among many others last week while trying to find solution for my severe battery drain caused by Email Sync and Google Services. By the way I am using Samsung Galaxy S6 running Android 5.1.1.
I contacted Samsung via live chat several days ago. They asked me if the phone has been dropped or got in contact with water (if your phone has been dropped or got in contact with water maybe it's the root of your problem--you should get your phone's hardware checked) to which I said no. They then asked me to boot my phone in safe mode and Email Sync (and Google Services) still drain my battery so much! They then suggested me to backup all my data and perform a factory reset. It worked surprisingly well! Now I don't even see Email Sync in my battery usage, and Google Services only uses at maximum 5% with High Accuracy (in Location) selected.
It turns out the culprit was one of my third-party apps. It was Doze battery life saver--some people swear by this app so I think maybe it works with some types of phones but I also saw one user complaining about how Doze's VPN "broke" their phone's GPS, making Email Sync and Google Services drain their battery, even after uninstalling. So I uninstalled that app, backed up everything else, and performed a factory reset, which worked well. Do you guys have any kind of battery saver or do you use some kind of VPN? If you do you might want to try uninstalling them (AND perform a factory reset after). Uninstalling them only might not work! I tried that and I still needed a factory reset cause the app created havoc inside my phone's system. I don't know what it changed but factory reset certainly did the trick of reversing whatever that app did.
So that's it. No more battery drain, even with 3 Exchange accounts (set to Auto-sync) in the native email app. You guys might want to try doing a factory reset. It doesn't even take that much time. Just back everything up, then Google will download everything for you after your phone turn back on. Cheers! Hope this helps someone.
View attachment 89212View attachment 89169View attachment 89171
Has anyone experienced this issue? I've seen some write ups on other sites that implies that it's an bug in the Samsung client software. I have a customer with this issue and trying to figure out if I can do anything to resolve it or not. Came to me saying the battery was dying quickly. I quickly realized that the Exchange account server was using 55% of the battery and looking at the data, accounted for over 400MB of data. This just isn't right. So I deleted the customer account, added mine and charged the battery back to 100% for testing. After adding my account, I checked the Running Apps and it still looks like it's using way too much. Exchange Services using over 25MB and Email around 40MB. Doesn't look like that on my Motorola RazrMaxxHD running the same Exchange email account. On my Razr its only 8MB on one and 7MB on the other. Something is wrong and I'm looking for suggestions. Should he return this thing or what?
I cannot believe this issue has gone on for over 2 years. Actually I can. My phone died on December 21st because of this issue, the phone was overheating like crazy everyday, every minute of every day because it was trying to access the wrong server address for my outlook.com account. The phone was always hot and the battery life was horrible to the point where I was using for batteries a day. They were cheap and I tried them in wall chargers but I didn't see coming what happened.
Slowly but surely I began to lose things. Eventually needed factory reset and what a pain in the neck that is. Then after the factory reset, under the clear blue sky I lost my calendar entries. Then I lost my email settings and I have to put them in again and I lost them again. There were times when I had a blue border around the screen but eventually went away or I hit something and the screen just expanded and eventually that will go away. My phone also was shutting itself off a few times a day.
So what happened? The phone got fried by all that access to the Exchange server because the server address is wrong. I didn't discover this until I bought an LG v10 once the note 2 died. It was getting very hot and battery life on standby, without me touching it, was four to five hours. On the lg v10 blog section I spoke to some people and they told me to look at the battery access report as you did and lo and behold the numbers were used for an account that I hardly used. It was up around 60% the battery life.
So I called LG and they gave me proper addresses to access the Exchange email servers. The change was instantaneous and the problem disappearing was instantaneous. The battery lasted forever in the phone but never had again except a little warm after charging.
Then I realized what has been going on with my note 2 for quite a long time. It was fried. I don't know how Samsung and AT&T didn't know about this. I believe it's their responsibility to watch these things for us and if Microsoft changing server addresses, push through updates so that when we set up an exchange account it goes in right. Its not like I set up an exchange account years ago. I was having trouble getting Word and Excel working on the phone and I killed and restarted that outlook.com account at least 5 times, using the automatic setup. So, below please find the posting that I put on to the LG v10 blog and I hope that helps you set up your Exchange email account, if you already haven't.
Very very very good news, there is a fix for the exchange accounts. I got onto tech support at LG and they sent me a link that had the way to fix it unfortunately it didn't have the whole fix. So I called them and they gave me the second part of it but they couldn't provide a link or something I could copy and paste.
first part you have to set up account as an IMAP account through the email add account. Not the Microsoft Exchange don't pick that. Then when you select I forgot what the selections were but you have to select instead of Microsoft Exchange when you get a choice you get Microsoft Exchange IMAP and POP 3 select IMAP again not Microsoft Exchange. Obviously it must be a manual setup.
Then in the incoming settings you have to put in IMAP-mail.*Outlook.com. select SSL for security and I believe the ports were correct once you select the SSL.
They said an upgrade is coming through but if you're having a problem this works now.
For outgoing, you have to change the server to SMTP-mail.*Outlook.com. . For security you have to select TLS (accept all certifications) or something like that and again the correct port will come in and that's basically it.
I did it and it work fine and the phone is as cool as a cucumber. And the email came right up. Isn't that something. What's strange about this is that it's a fix also for the g4, The Lancet, and something else I can't read, VK 815 I don't know what that is.
Here are those server settings again:
UTLOOK.COM*POP3 SERVERSIncoming mail serverpop3.live.comIncoming mail server port995 (SSL required)
Outgoing (SMTP) mail serversmtp.live.comOutgoing (SMTP) mail server port587 (SSL/TLS required)Outgoing server (SMTP) authenticationyes, same settings as my incoming mail serverOUTLOOK.COM
IMAP SERVERS
imap-mail.outlook.com
Incoming mail server port 993 (SSL required)
smtp-mail.outlook.com
Outgoing (SMTP) mail server port 587
(SSL/TLS required)
I used TLS (Accept all certificates)
Sent from my LG V10, an AT&T 4G LTE smartphone
I have only had this issue after the latest operating system update. Also, it is intermittent. I can go for long periods without noticing it and then for some unknown reason it rears its ugly head and takes chunks out of my battery. I was expecting it be fixed with some future updates but it has been a few months now and it is still an issue.
noroldie
