Android4life47
- Oct 18, 2013
- 226
- 0
- 0
Here is a update on the iloome flex.. It's a no go the corners are lifting up and are not sticking to the glass. I E mailed iloome asking for a refund I'm done with them
There seems to be a somewhat common misconception that the iloome 8h Flexmate is not glass. It is glass ergo the 8h rating.
I suck at putting screen protectors on and mine went on just fineTried installing the SUPERSHIELDS - Near impossible to do... I got a crappy halo on it and even the corner where I had to peal it up to put it on straight didn't adhere right. I hate installing screen protectors. I guess i need to find a speigen or something... Ugh this is so frustrating.
I managed to install the iloome screen protector and there is a small raised edge at the top or bottom depending how you placed the screen
Mine was on the top left corner, then it started to raise right across the top running to the right corner. Like I said I'm done with this glass screen protector b. S I'm just going to get a zagg yes I know it's not glass and that it's just a film but at this point I need something that's not going to come off so easily
I have Spigen's plastic film protectors (the H3 rating ones). I wish there was an oleophobic one (not out yet, it seems), but it went on very well, and its sticking to the screen extremely well. No haloing or lifting up at all. extremely clear, no issue with the s-pen, I just wish it was oleophobic.
