Best Galaxy Note 4 Tempered Glass Screen Protector
your halos look fatter then mine. I still have the first Zagg on the phone. I have another Zagg and the Alpha glass just sitting here collecting dust.
Does that Tech 21 have the elongated opening for Verizon?
It appears so.
Sent not from just an oversized phone but my Samsung Galaxy Note 4
Still with the revised version there is a halo on both sides. Not terrible but it's there. Besides that there is no difference between the tempered glass and the regular glass. Clear, smooth and fluid. SPEN works flawlessly too. I probably will just keep it on unless it starts to really get to me.
How many tries did it take to put it on before you were satisfied with the alignment? It seems like the halo gets more pronounced the more times you lift it up.
The other question is should I try the zero lemon or mybat first on my white at&t note?
Since no one is answering my thread about this: has anyone tried the Rhino Shield yet? (For this, or any other phone.)
To me it sounds like it'd be in-between a glass and plastic screen protector and would hopefully provide the protection of glass, with the fit of plastic?
http://www.evolutivelabs.com/pages/rhinoshield
I'm also wondering how the S Pen would perform with it and how'd it feel?
ZeroLemon. Amazon seller Fenix select does prime shipping and has the newer version.
sent from my Samsung GALAXY Note® 4
It appears so.
Can you put up a picture showing the bottom (charge port area) and back of the Tech 21 case with the phone inside? Thanks.
Does your Zagg have the halo along the top by the earpiece front camera?
I just got the zero lemon from Fenix select delivered yesterday. Just wondering how I know if it's the updated version? Also Keyz could you let us know with pics where to position the tape when installing? Thanks
The new one will have a rounded cutout for the home button and the old one will be square and long at the bottom.
1. On the tape you want to dry fit it first to see how its gonna lie.
2. Then put a piece of tape literally about a hair wide to the right of that along the right side.
3. Realign the protector along your right edge and align the top so the top edge of the protector is just high enough you can see the whole ff camera cutout under the protector.
4. Then put a piece across the bottom to mark that. Now you have a guide of sorts.
5. Clean screen careful not to transfer tape adhesive to screen.
6. Use your tape as your guide, and drip it down.
7. Peel up tape and cross your fingers.
Worse case scenario, you're off a little bit just try it again, but make sure it clean before you lift up because it will suck in anything that's around when you do. Hope that helps. Good luck.
Thanks for the help Keyz. I went just a hair too low on first and only attempt with the zerolemon. The very top of a image of a selfie looks a little blurry. I was too afraid to lift it up and risk getting dirt underneath. Just gonna live with it for now. Little halo on the left side. Not bad tho I've seen worse.
Yeah they're tough to get perfect. Just looking at the home button cutout you can see your a smidge left of center. An adjustment should get you there. Agree on the seen worse part. This is the best so far for me and I've tried almost all of them.
I have the original zerolemon and I really don't have anything bad to say about it. People do not like the glass over the selfie camera lens but I just don't see a practical effect from it. Selfies look fine. Thing has a halo particularly since it is much larger than the current version. However the thing has not budged since the day I installed it and the halo is no larger today than it was that day. Has been fine the entire time. I completely understand the design direction they have taken going smaller. Not sure it really matters one way or the other.
What I really notice is that it appears to be as fingerprint resistant as any glass protector I have seen.
Popped the screen protector out of the Otterbox Defender and the case fits fine with the Zagg glass and covers my top halo. If only the Zagg was on a little lower, all would be fine. :-\
Still have a second Zagg and the Alpha glass collecting dust. :p
Just worry about the hard plastic interior of the defender scratching the painted sides of the Note 4. :(
Don't think I'll leave the phone in there too long.
My wife had her note 4 for 3 weeks without a screen protector. She dropped it once. About 3 feet to kitchen floor and the screen is shattered.
Iloome Screen mate flex 8H on black T-Mobile. Halo free. The two left and bottom right corners aren't completely adhered but it's an extremely small amount. Very hard to see unless your looking for it. Only been two days, but the corners are actually laying better as time goes on... YMMV. This is just my result.
Impressions:
Looks - great! Larger than the small tempered glasses that are halo free. Crystal clear and no adhesive border like the ZeroLemon (previous favorite) or Supershieldz. Looking straight on, you can hardly tell it's there.
Install - just as easy as the other tempered glasses. Its thinner so you have to take a little more care, but some basic process. Requires a little squeegeeing but was easy with the supplied card and cloth.
Feel - someone coming from plastic will love it, coming from a ZeroLemon or mybat, it won't feel the same. Not bad by any means just not as slick. Added five coats of rain-x and now it's pretty dang close.
Overall, this is my new protector till something better comes along. Something to note® 😆 is the corners while barely noticeably on my black model, would be completely unnoticeable on a white model. I'll post some updated pictures in a week or so to show how it's holding up.
Keyz, if tempered glass screen protectors were a stock traded on the NYSE you would be the majority shareholder. Lol
Guilty as charged.
Impressions:
http://tapatalk.imageshack.com/v2/14/12/22/1474ce9c5d77a04ccc8d00edb960566f.jpghttp://tapatalk.imageshack.com/v2/14/12/22/89c23e3b5c8e91691443d62a64d94907.jpghttp://tapatalk.imageshack.com/v2/14/12/22/a5874db3d210c3a82e4a5d1a56c514fb.jpg
Thanks for this! I've had this in my cart on amazon for a while, hesitant to pull the trigger, but also satisfied with my spigen crystal that I have. They're not bad for what they are and the price. Think after your review I'll go ahead and order the iloome.
No cutouts, right?
I went with the BodyGuardz. The rep at AT&T applied it and got a single little piece of dust under it. I'm seeing if I can live with that. Otherwise, it's fantastic.
from the IV
GermanAndroid2403
