Best launcher for Nook Color Rooted with Autonooter?
I installed Zeam from the market, but when I go into setting up the wallpaper and into the live wallpaper and select one, it seems to just hang on the screen 'loading live wallpaper'.
Any thoughts? I am on rooted stock NC.
Thanks.
I like Zeam. I've tried Launcher Pro and didn't really care for it. Zeam seems to give more control over the look and feel of the UI. I'm waiting for the Honeycomb revision which uses the fully released SDK, and then I'll use it and do away with all of the Barnes & Noble stuff all together.
I previously had Honeycomb, now just using Zeam and am very much enjoying it. Does everything I need
Thanks.
The first post in this thread, #12 tip may help.
http://forum.androidcentral.com/bar...work-arounds-issues-stock-nook-color-rom.html
12. Why aren't my favorite live wallpapers working?
I'm not sure, but here's how to get the rest of them going:
Download this file: http://db.tt/ur0c98s
It will fail installing, but if you use Root Explorer, copy it from your download directory, go to system/app, set as r-w... Then long-press on any file in that directory, and look at its permissions. Now paste your LiveWallpapers.apk there and change its permissions to match the others. Your live wallpapers should work now!
Notes:
1) The permissions are simply 644
2) The link he mentions does not work so get it from here:
LiveWallpapers.apk
So basically get the file, move it to system/app with root explorer, making sure the directory is read/write so you can put it there, then change its permissions to 644.
lindbo10
