Bluetooth not connecting after flashing Virtuous
dustinfrank
149
Anyone else have this problem? I've flashed Virtuous with the Incredible Revolution theme, and the only problem I've run into is that I can no longer connect my bluetooth headphones. Is there a fix for this?
dgalanter
159
Try "Bluetooth Fix Repair" in market. May or may not work. Seems to have helped the same issue with me, but not totally.
dustinfrank
149
thanks for the tip, but no luck there either. It will see two computers here at my office, but not this little headset i've been using at the gym.
PvilleComp
4,146
603
Are you having a problem entering the PIN?
If that's the case you need to click the little OK at the bottom of the input screen and then the keyboard will enter the PIN.
I had the same problem until I hit the OK by mistake.
debzz
