Jgonzo1299
- Jan 23, 2011
- 108
- 6
- 0
I have Froyo+2.4 super clean. How do i put the boot animations on. Im trying to put the halo reach (not the GIF one.. the second one listed). Theres no System/media/video directory.
Hey how can u get sound on the r2d2
Sent from my SCH-I500 using Tapatalk
Current kernel does not allow for sound on boot animations. Have to wait until the devs get their hands on source code to put out custom kernels
I am not certain that r3d2 had sound to begin with.. I never installed that animation on my phone..
You are completely correct current kernel doesn't support sound.
Cannot wait for the source code to get released.. undervolt would REALLY be nice!!
Thanks Landshark!
Agree on the undervolted. Hopefully it will address a lot of the battery drain issues everyone is having. I'm still having trouble with switching between themes. I created 4 nandroid backups set up the same way, sc 2.4, theme, adry's full batt pop up disable, maint pack, & nuance. First build was with Touch of Blue. Then Blackish Storm, SuperDark, & nitsuj17's black Aosp. Created each one by booting to recovery & flashing everything one after the other, ROM, theme, batt pop up, maint, & nuance. When I was all done the only one I could restore without getting hung up in a fc loop at the boot animation was Touch of Blue. Can't seem to figure out what is happening.
You should be able to swap out the bootanimation.zip files as long as the format is similar. That is why we can copy many of the animation files from other phones.
I'm not sure if this has been addressed or not (or if I'm dumb for asking since its just a boot ani) but can I install the Honeycomb Theme boot animation for SC 2.6 framework on SC 2.4?
When i was on SC2.6 i saved a copy of JUST the boot animation (Root explorer: /system/media bootanimation.zip) because I really liked it. Would it be possible to use it on SC 2.4? My theme is Steel Blue V1.1 and it has a cool boot ani, but i really liked the honeycomb one.
Think I'm going to try just replacing & renaming the boot animation in /system/media with the honeycomb boot animation and see what happens
Edit: Work and going back to school as an adult has really put a hindrance on my 'me time' with my Android phone and learning all this stuff! LOL =)
hey, can you upload the honeycomb boot animation? i'm also on SC 2.6 w/ Blue Steel and would like this boot animation over the one with Steel Blue.
Here is a link to the honeycomb boot from Superclean 2.x. You will need to either push this to your phone with adb or copy with Root Explorer over the current bootanimation.zip
Go to root explorer, system>media, then rename the existing bootanimation.zip to bootanimation.zip.old
Then paste the Animation you want in there and rename it bootanimation.zip
Then you're good to go
Sent from my Froyo'd Fascinate via Tapatalk
