Bricked LG G2, Stuck at TWRP, No Download mode!
I get this error
dd: writing '/dev/block/platform/msm_sdcc.1/by-name/fota': No space left on device
65537+0 records in
65536+0 records out
33554432 bytes (32.0MB) copied.
2.280673 seconds, 14.0 MB/s
before trying anything else just type in these commands
What worked for me was from the TWRP terminal command was to type
dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/fota
then hit enter
type
dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/misc
then hit enter and reboot.
got help from the IRC xda-devs for the second step to complete the fix.
Thank you so much! Just applied the Sprint OTA this morning while half asleep not even thinking about it. Got stuck at TWRP. Tried your method and it worked like a charm. Now I'm back to how my phone was before being rebooted for the update. I gotta stop trying to use my phone when barely conscious...
then hit enter
type
Does the phone need to be plugged into the*computer for this? I really need help with this. It said it was an update so I clicked on it and it never restarted normally it was stuck on the "twrp" mode and wouldn't let me go to my home screen.
I get this error
65537+0 records in
65536+0 records out
at the bottom it should have a button "select"click that.
when i type in the code for both they say there's no space left. what should i try now?
I get this error
65537+0 records in
65536+0 records out
I'm actually getting the same error. Not sure what else we can do, can anyone help out?
I have the D855 G3 (TMO) and have the same issue... I'm trying to figure out how to type your string of code in Terminal Command. When i enter Term Command it appears to be a File Manager. Would REALLY appreciate any help.
There you just want to leave it on the root of the drive and then hit select and it will bring you to the terminal to enter the stuff.
And FYI I did the same thing, accepting the OTA and then got stuck in a loop and this command worked.
I too have the G3.
how do I get to terminal command in twrp? When I click on terminal command it takes me to all my folders. where would I find terminal command? Running TWRP 2.7.1.0 on rooted LG G3
I would like to know if you can help since you already pass for something equal.. I have been without phone for the last 2 days..
I search a lot to find if someone with my phone model: wiko cink five / micromax a 116 was having the same issue, but now i can see that my problem is similar to yours.
This is the current situation:
I have a backup from the previous ROM, and i have a new ROM 4.4.2 kitkat that i´m trying to install.
The problem is that everytime that i use TWRP to install and flash the new ROM everything goes nice, but when i reboot right after the phone logo, TWRP opens again and i´m stuck..
I tried to restore to the old one but no lucky.. No matter what i do everytime i reboot the phone it will always open the TWRP..
My question is: Can i adapt the terminal code that you post and make it rock for my own phone model ?
Sorry for being boring... but i'm a little bit desperate because i just bought this phone 2 months ago and i´m afraid to screw him...
Best regards,
Jorge Maia
I have the same error did you get it fixed
65537+0 records in
65536+0 records out
I get this error too
65537+0 records in
65536+0 records out
Can anybode help me? I want my phone back! :-\ :-\ :-\
what worked for me was from the twrp terminal command was to type
then hit enter
type
Got help from the irc xda-devs for the second step to complete the fix.
thank you so much!
65537+0 records in
65536+0 records out
Just go through with the steps exactly as described it works. Just brought mine back to life yesterday using this advice.
were do i reboot it from my system or bootloader or power off or which one and i dont have an enter button it says go and when i reboot it with my system it tells medownoad su to root my phone and whenever i put download or do not donload it stays on the lg logo only helppppppppppppppppppppppppppp plzzzzzzz
paulmloucks
