Building your own ROM
The problem is that the custom carrier label is a two part commit. You need to pull in the other part that goes in /packages/apps/CMParts/whatever ;)
Reactions: jdcnosse
try to get repo from here
I had an issue getting it from the tutor place and couldn't get an init
Code:
curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > ~/bin/repo
chmod a+x ~/bin/repo
It worked :). thanks so much.
Actually I pulled in the CMParts part, I didn't pull in the frameworks/base part. lol
alright it finished compiling. but no .zip. do i have to zip it all up?
EDIT: I zipped it up and get a huge .zip file. Its like 565 mb. What happened haha?
What command did you use to compile? If you use make bacon, it will give you a couple of zips.
I haven't done a build for ever, but isn't there an option to build all devices? I was wondering if you accidentally selected that instead of the ov
It would still make a system.img it looks like mkyaffs didn't work correctly make sure you run
Code:
make clobber && make clean
im running make otapackage instead and if it doesnt work im done. im sick of all these stupid errors im getting on linux
Some say warning then i cant catch the rest because it goes to fast. heres one i got on a screen shot.
I posted about that error a few pages back. You might want to research this thread a bit to see how we work around certain peculiarities when building. ;)
The omap error is fixed by applying the following fix, you want to add the + line (removing the + of course):
Edit- look for this code segment in /build/core/pathmap.mk
Code:
FRAMEWORKS_BASE_SUBDIRS := \
	$(addsuffix /java, \
	    core \
	    graphics \
	    location \
	    media \
	    opengl \
	    sax \
	    telephony \
	    wifi \
	    vpn \
	    keystore \
	    voip \
+            omapmmlib \
Let us know if you get other errors, let us know what they are, and we will try to help.
Patience is definitely one of the keys to building Android! ;)
Code:
	    core \
	    graphics \
	    location \
	    media \
	    opengl \
	    sax \
	    telephony \
	    wifi \
	    vpn \
	    keystore \
	    voip \
+            omapmmlib \
How do I do this?
Sorry, I left out the filename: /build/core/pathmap.mk
Look for the section I posted above, and add the line with the + (leaving out the + of course). ;)
Note- I edited the above post so others won't be confuse.
I went and find the first post and based it off that file. as far as i can tell its working because the make bacon is taking a lot longer. ill reply back to see if it worked.
It worked. First build is done. It came out with 2 .zip files. which do I use the cyanogen or the IHO or are they both the same.
Im having some trouble getting started. I have ubuntu installed,and java,and android sdk. But still cant get it to work once booted into ubuntu.
The update zip with the corresponding md5 is the optimized one. You can use either, but the optimized one of course performs better and is smaller.
SeVeR
