Building your own ROM
Now open a terminal and type sudo mv /home/alexandra/android /usr/local Then hit enter. there is a space between android and /usr/local
got an error downloading it
felt it wasnt needed
ill try again
Man! I didn't spend an hour of my life digging up the "how to install Java sdk 6 on ubuntu11" because it wasn't important. You wont get anywhere without. I didnt even get a thanks. And I'm only 3 thanks away from 100! Ok I'm over it. Its a long painful process setting up your build machine and get your first build done. But its a good learning process
Next open terminal and run these commands one at a time. When you run repo sync it will take a long time to finish.
cd /usr/local/android/system/
repo init -u git://github.com/inferiorhumanorgans/android.git -b gingerbread
repo sync
im sorry!
seems like running the script posted above put a system folder in the android folder but deleted all the SDK crap
sdk crap must not have been there to start with. you were supposed to have made the system folder before running the commands
Did you rename the android sdk folder in your home folder to android before you moved it to /usr/local
redmercer
