Camera Failed Problem
kit717
14
I know there have been posts on this before but I have tried a lot of these suggestions and still have "camera failed" error on my S3 4.3 stock rom. Camera was perfectly for couple of days after ota.
I did update the firmware ZDFI02 using #*34971539#, and it does says both phone and cam is ZDFI02.
Thanks guys. Ask me for any other detail you need. I really wanna solve this problem.
Hello! Did you clear the cache via Settings > Applications > Camera?
Give that a try and see if the issue is fixed.
Yes that was the first thing I tried.
It used to work with at&t 4.3 ota update then one day the camera stopped working. Right now I am running CyanogenMod 10.3
But when I had 4.3 rooted I tried updating the 34971539 thing and also updated the camera firmware to zdfi02 but it never worked.
Sent in for Samsung repair facility. First I had to unroot the phone and factory reset. They replaced the camera component without any charge.
Sent from my Nexus 5 using Tapatalk
I have had the same problem twice. Clear the data on the camera. You know how to clear the cache, clear the data as well. Worked like a charm for me. Hope this works for you. It is really frustrating not having your camera!
TomyJones4567
