Hi
So i have the common 'camera stopped working' message. I have done hard resets / soft resets /deleted cache and everything else. So installed a camera app off play store and the camera does work albeit in wide lense mode only and any video capture is upside down.
So i know its a hardware fault. What I therefore ask is......
Could it just be a loose connection inside that needs pushing in or does it sound like I need a new camera?
The online replacement help makes it look easy. Is it as easy as it looks??? I've changed screens and components before with no probs on Samsung so capabe.
Kind thanks
Jim x
Kind thanks
Jim x
