vzwuser76
- Jan 28, 2011
- 1,669
- 26
- 0
There are some signal apps available on the Play Store that will give you the information. The 6P is a little funky and it isn't reporting SNR... rather opting to use ASU... which is... I kid you not... Arbitrary Strength Unit. You gotta love that name. But it's basically just a rating of the overall quality of the signal. The higher the better. If you have a strong signal yet the ASU is low... that points to a poor signal to noise ratio.
So ASU is similar to the Quality of Service (QoS) measurement that they use in VoIP?
