Say what you want, but none of the keyboards outside of the stock keyboard(Jellybean) is even close to the level of the iPhone.
The thing i can't get pass is the cheap plastic. The screen scratches easy. Not sure what to do. Is it really that big of a deal. 3 years is a long time
In areas where the device should "just work" it sort of falls short, like the keyboard. Say what you want, but none of the keyboards outside of the stock keyboard(Jellybean) is even close to the level of the iPhone.
Hello,
I am still on the fence about getting the S3. I currently have an iphone 4 and my contract is up sept first. I have been really looking at the S3. I love android and how customizable it is. The thing i can't get pass is the cheap plastic. The screen scratches easy. Not sure what to do. Is it really that big of a deal. 3 years is a long time
Thanks
SHiFT.
This MAXX user has no idea what you are talking about...loose buttons? None here...motor spin? What are you talking about?... I am here to support what EVERY professional review of the MAXX has stated...the build quality of the phone is tops. Certainly as solid as wife's 4s. If Kevlar, diamond cut steel and gorilla glass are not premium enough go buy a TAGG.
Rant aside if the S3 had been available I would have certainly considered. Its a beautiful screen and you will enjoy it. I personally love the way it feels...
That said don't go knocking the MAXX..op is clearly a fringe opinion.
Sent from my DROID RAZR using Android Central Forums
To be fair, while some other apps have crashed on me, it's usually just the Facebook app. It was equally horrible on the iPhone, and still is on my iPad. I always thought it was just an iOS thing. As far as the lag goes it always seems like animations aren't buttery smooth like on the iPhone, but I changed some settings in the developer options that have seemed to help.Where are you seeing the lag? Which apps are freezing? Could it be the apps that you are running causing the issues?
You know that was the first keyboard I downloaded, and while it has been usable I still find myself hitting backspace way too much. The Jellybean Keyboard I downloaded was nearly flawless on the other hand. I am a fairly rapid typer, and I hate having to keep hitting backspace every time I mess up. And while it's not a deal breaker, I just wish the native ICS keyboard hadn't been removed.On this point I have to strongly disagree. I use Swiftkey 3 and it blows the iPhone's keyboard out of the water by far. I've even demoed it to iPhone users having them take my phone and blast away typing a few sentences (and I always tell them don't correct or use backspace just go!) and they are always in awe how accurately it corrects to display what they intended to type. No way in hell the iPhone keyboard beats Swiftkey 3.
I also don't have any lag whatsoever.
Rev.
edited by moderator
How did you setup Swiftkey, did you choose the Rapid typing option or Precise? I set it for Rapid and chose "Spacebar will complete the current word" rather than insert a prediction and it works so incredibly well it's mind blowing. I also don't have the arrow keys turned on because the spacing messes me up and I use the pumpkin theme which I seem to graphically prefer. With Swiftkey I can type two words both incorrectly and miss hitting the spacebar and it will correct and separate the words.
Rev.
