Car mode keeps poping up
Rdjinc
Active member
Nov 27, 2010
41
today I had my phone on charge and it changed in car dock I'm guessing then I exit and it just goes back any clue or ideas
Sent from my SPH-D710 using Tapatalk
handsomeprince#AC
72
YES! The same thing has happened to me like 5-6 times...very annoying actually; each time have to do a battery pull to fix it.
Rdjinc
Active member
Nov 27, 2010
41
My phone locked up earler also had to force reboot bar was at 65% then 20 % after it came back up before today it had been perfict
nkd
666
66
has happened to me a few times and it is very annoying, I almost threw my phone on the ground with frustration because I was in the middle of something very important. I think we are in for another lack of updates from samsung. I hope I don't regret buying it.
rogfamily400
5
If you go into settings, then go to motion settings you will see an option for Double Tap to start voice talk. Uncheck that box. I had the same problem, everytime I hit a bump while charging it would activate the double tap. This should fix your problem.
Reactions: Rdjinc
Rdjinc
Active member
Nov 27, 2010
41
Thanks I'm trying it now
JayWill
2,631
571
Yes Double Tap appears to be bugged all to hell. I've never been able to get it to work after the initial training tutorial, so I've had it shut off since very early on.
Rdjinc
Active member
Nov 27, 2010
41
No luck turning it off it still pops up sprint service center ordered a replacement they have no clue thanks for the help
dorrien12
539
I opened Svoice from apps, then hit menu key for settings and unchecked double tap to open. And it worked...
Sáenz
