Charging the phone
If you charge a Li-ion battery above about 75% and leave it there long term, that's bad. It causes accelerated breakdown internally, reducing your capacity. Even overnight can cause some degradation.
Charging to full and using it right away is generally fine, as the battery will not remain at that high charge level for long.
Actually recommendations are keep it topped as much as possible. The closer to 100% you are charging, the more cycles you can squeeze out. But there's a point when it becomes impractical though.
In every case I've looked into, holding a Li-ion battery at 100% leads to drastically shorter life. That's why they are shipped only partially charged, because they could be sitting on a shelf for weeks or months before being used.
If I remember correctly that's only when storing them. But if they're being used its supposedly not a problem. Although it does contribute to wear and tear, there's the benefit of increased cycles available. We'll just have to balance it.
That's why I distinguished in my first comment between looking ten storage and charging to use. Even then, it can cause problems. I once killed a battery in about 6 months by leaving it plugged in almost constantly wanting to have power just in case I suddenly wasn't around an outlet. Keep in mind, I was actively using the phone a lot, just while plugged in. That was before I started researching charge and usage habits.
That's why I distinguished in my first comment between looking ten storage and charging to use. Even then, it can cause problems. I once killed a battery in about 6 months by leaving it plugged in almost constantly wanting to have power just in case I suddenly want around an outlet. That was before I started researching charge and usage habits.
Ah. I think there's the difference between leaving it plugged and just a low range drain cycle. In leaving it plugged there's still a current in the wire causing heat. And we don't know how fast it can burn through the overcharge protection circuits.
It's not overcharging, which would lead to the battery bursting. It's an internal breakdown that reduces the ability to store and transfer energy. Once charged, the phone shuts off power to the battery, in a manner of speaking, leaving it there while using the charger to function. Similar to how you can disconnect the battery from the car once started and it'll run just with the alternator alone.
I keep mine topped off as much as I can. I keep it on a wireless charger at work and at home.
If I can I will have mine charged for around 7am then run it through to the next morning to do the same, usually between 40 and 60% left before charging unless I have a quiet work day with more play time.
I usually put it on the wireless charger when I'm in the 20%-30% range. Which so far has been at the end of every day, around 11pm after talking off the charger at 7am. I only use fast charging when I'm plugged in. I use the wireless charger over night, and charge at the "standard" rate.
With that said, remember the batteries in the S8, S8+ and Note8 are now designed to degrade to 95% optimization after 2 years or normal use, by Samsung's design. If it weren't for the Note7 issue, Samsung may not have decided to focus on this kind of thing for the batteries.
Lithium batteries dont really care what you charge it to. Even when the phone says 100% the battery isn't at 100%. Just charge it how ever you want to but it makes no difference in battery longevity. I havent seen anyone replace or have a bad cellphone battery in several years. Now heat is the single biggest issue. And my note stays cooler then my iPhone 7plus did.
I pretty much top off all day at work leaving it on the fast wireless charger. At home when I know I'm not going anywhere I'll let it get to around 30% then put it on the charger. This rarely happens becuase the battery has been very impressive so far. I hope it continues.
caritas
