ARCHIVED: Clockwork Mod Recovery V. 0.5
Status
Not open for further replies.
well i do own a p500 not a sprint version....ive managed to somehow bring it into emergency mode but its ninja emergency mode...cuz it still dosent see the phone...:(
Sorry to say this, but why would you flash something made for a different phone on your phone? Sure, they are pretty much the same hardware, but the kernels are different.
Lol I did that when I first got my hero. New to Android, I flashed a G1 kernel. Stuff happens.
You could always try to reload the stock software,not sure what the process would be you would have to check that out in the right area.
@smccloud- you should add in big text to first post don't flash unless you have the LG Optimus S from Sprint;) just so no one else,makes the same mistake.
yeah well im back and kicking :lol: hopeing to cm7 port to p500 :( but i dont know why it gives me system/bulid.prop error when i try flashing
Hmmm... would it be reasonable to have the menu use both the button's on the side of the phone as well as the menu/back buttons on the front of the phone for enter and back?
Any way to have Koush update the Rom Manager so we can use it with this recovery?
That is the end goal. Smc just needed to get clockwork working, and then it's up to Koush (creator of Clockwork) to accept it and provide updates.
Ok,
I'm trying for an Optimus S w/ a bad ESN so I don't have to worry about bricking mine. Yes, it will make it a little more difficult to test things like the radio but meh....
Status
Buka Blokir BRImobile
