Compiling and unofficial CM14.1 build for samsung Galaxy S5+ (kccatxx)
Elevennails
4
Hi wondered if any of you can help, i'm trying to build a branch of this distro,
https://github.com/IonKiwi/android_device_samsung_kccat6xx
for a kccat6xx device, as i'm trying to add USB WIFI support for RLT8188C_8192C.
I've not yet added my drivers as i wanted to get the standard build to complete first.
This is my first go at building an android kernel from source. I've been using sktjdgns1189, compiled version of CM13 for well over a year and it's been really good. (few teething problems but so much faster than stock!!!!)
Here's what I've done to compile this version so far.
mkdir ~/bin
curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
mkdir cm14.1
cd cm14.1
repo init -u https://github.com/CyanogenMod/android.git -b cm-14.1
repo sync
The above all complete successfully
I've created the .repo/local_manifests/kccat6.xml file with the content of the readme.md from your source
repo sync #files appear to add to my local copy
source build/envsetup.sh #completes successfully
my problems start here.
brunch and breakfast both give the same output for cm_kkcat6 for both...
brunch kccat6 and kccat6xx the same as the output below.
$ brunch kccat6
build/core/product_config.mk:245: *** Can not locate config makefile for product "cm_kccat6". Stop.
Device kccat6 not found. Attempting to retrieve device repository from CyanogenMod Github (http://github.com/CyanogenMod).
Repository for kccat6 not found in the CyanogenMod Github repository list. If this is in error, you may need to manually add it to your local_manifests/roomservice.xml.
** Don't have a product spec for: 'cm_kccat6'
** Do you have the right repo manifest?
No such item in brunch menu. Try 'breakfast'
I've tried renaming my .repo/local_manifests/kccat6.xml to roomservice.xml and rerunning repo sync, but it still barfs with the same message on brunch and breakfast.
Can anyone help?
Elevennails
4
The download of the Cyanogen repo completed successfully was massive! I think the error has something to do with this being an unofficial build that wasn't listed on the old site. (prepared to be wrong though) i'll give the new github link ago and let you know how i get on. Thanks.
Elevennails
4
Ok I've switched the repository on git to lineageos but i still get the same message as before. I think the problem has something to do with the image being unofficial. Unfortunately the S5's had so many variations the S5+ (kccat6xx) only ever had unofficial CM releases.
brunch kccat6
including vendor/cm/vendorsetup.sh
build/core/product_config.mk:249: *** Can not locate config makefile for product "lineage_kccat6". Stop.
build/core/product_config.mk:249: *** Can not locate config makefile for product "cm_kccat6". Stop.
Device kccat6 not found. Attempting to retrieve device repository from LineageOS Github (http://github.com/LineageOS).
Repository for kccat6 not found in the LineageOS Github repository list. If this is in error, you may need to manually add it to your local_manifests/roomservice.xml.
** Don't have a product spec for: 'lineage_kccat6'
Lovepreet Birdi
brunch kccat6
I'm facing the same issue, if you've found any solution can you please tell me?
TexasIndia
