constant SD Card Notification "SD CARD for transferring photos and media"
[This is happening with me as well and all did was press and hold the notification and it took to"system iu" and I just turned off all the notifications" I hope this works from you and I, we shall see.
O did what you said by holding my finger down and it tells me I'm not allowed to disable the notifications for that. The wierd thing is that it didn't do this with my old card. Can I seriously not get rid of this plz plz someone help.
Finally finding this issue.
Most likely & common culprit is Android! Likely even multi versions.
I'm using 8.0.0
First is this even a valid notification?
Likely not. If so, what does it mean?
It offers to Explore & Eject but is Clear as Mud for what's needed!
SanDisk referred me to Google.
Google says nothing.
The advice to ReFormat is only practical advice for something but sounds like it's clear is only temporary.
Like to try Eject but being ignorant & cautious I'm reluctant until I'm sure.
Can anyone speak to that. Don't think it would erase All My Data but.
And will it fix this head ache?
Google & SanDisk should address this and advise & resolve but that will be the day. Hoping some help, Thx.
RangelS25
