Couple noob questions....
OKay, I have a noob question... how do I get the default ringing to be the mp3 I want to use?
place the mp3 in a folder called ringtones
for alert notifications put them in a folder called notifications
then when you go to change your ringtones, the mp3 should show up
That worked wonderfully. Awesomely simple!
yes it will, but when you plug it in, you have to enable mass storage mode by dragging down the notification panel and turning it on.
how do I make the phone stop vibrating everytime I hit a letter in my texts its annoying
you mean on the keyboard?
settings, language and keyboard, touch input
then uncheck vibrate when typing
yes, you can do a *228 option 1 or 3 and it will ask what number you are putting it on, and the security code for the account.
i think you can do it online too
jeffnachatilo
