Crazy battery life!
conan1071
269
Look at these numbers. I couldn't believe what I was seeing. LOL
Sent from my XT1080 using AC Forums mobile app
You should see the battery consumption data for my retired Razr Maxx. But yeah, these phones can certainly be made to just sip power while being fully functional.
Fat-fingered from my D-Maxx. now Free
Odd. Your Android is using about half what mine does. It's always #2 and in the mid 20's...
You actually got about half that since you plugged in about halfway through and charged to just under full. But still, the battery life on those phones is awesome. I used to have an og razr maxx and loved the battery on that thing.
Noted via tapatalk
I've found the same thing. I charge my phone every night, but even after a day of heavy use, I never have less than 50% battery remaining. It is totally normal for me to have 4 hours of screen time and 17 hours since the last charge and still be at 65-70% remaining.
This was my worst battery day - it was on Saturday. After a bit over 18 hours, I had about 18% battery life left, with less than 2 hours screen time. I did do about twenty minutes navigation in the middle of the day (the first small steep decline in the middle of my graph), but the thing that killed it the most was sitting in a restaurant in rural NH for two hours, where there is a very, very weak signal and the phone often flips between 3G and 1xRTT for data.
On my last phone, it would have been dead within an hour at this restaurant. The battery on this phone is great, but a weak signal is a killer.
Hey! Where'd you find that cool graph of the history? Gotta go look for that.
Go into the battery stats display (settings->battery is one way.) Tap anywhere in the graph where it says how long you have been on battery, and it will open the "history details" display.
You'll see on mine that the large sink in %left from about 50 to about 20 came with the display off almost the entire time, while phone was in my pocket at the restaurant.
Here today. Could probably get another hour or so screen time before recharge
Found it. Interesting, my battery went nearly 2 1/2 days...and I airplane mode at night. I didn't use any calculus, but it's easy to tell that on my history, the decline is the same whether fully on or airplane. Which makes NO sense at all. But it's just a nice steady slope all the way.
I'm down to 64% after 3 hrs and 52 min.
The big users are the screen at 69% and chrome at 17%.
This is worse than my bionic.
If you want accurate replies you need to provide screen shots of battery usage and screen on time.
All is normal here. 47 hours strong, 3h45min on, 35% left
sweetrelaxgummies
