Custom bootup animations for the Droid X- Android Central bootup too
I'd like to try this - but I have no bootanimation files in my system/media folder - only an "audio" folder - but nothing else.
Running Apex 1.31 with Watermark'd Theme. Any ideas? Does Apex move the bootanimation file somewhere else?
I am also running Apex 1.3.1, look in /data/local and you will find it there.
I couldn't find the ApeX one either, so I just copied the new one to /system/media and it worked.
Any chance you can look over this file and help me figure out why it isn't working? I've even named the files the same as the stock .zip and the phone just shows a blank black screen until it's finished starting up.
Here is a link to my .zip on dropbox;
http://dl.dropbox.com/u/16737452/mazebootanimation.zip
Sorry to dredge up this old post - just joined today.
You have to make the .zip file with no compression (7zip setting would be "store"). Yours is showing compressed files inside the zip.
trying to use this on Samsung Captivate, and nothing shows, just black screen while booting, any suggestion would be helpful, any other bootanimation works 480X480 not work on captiavte, i've used other bootanimations and they work fine?
Master zx
