ARCHIVED: [DEAD ROM] nROM v1.6.3
Status
Not open for further replies.
Just tried it. Star turns green but when I back out of contact, it doesn't stay that way in the favorites like it has in previous builds/ROMs. That being said, I don't have my contacts syncing to Google since it seems to destroy the structure for when I re-sync with my Outlook/Thunderbird and I lose data fields. I've never had that enabled though in the past and it's worked. Tried a reboot. Maybe I'll try to flush cache or something, perhaps I'm only one having this issue. Easy enough to work around if no one else having the issue.
It's for sure working for me :( I'm not sure what is going wrong there. I'll try to look into it though.
You would use VC, as there isn't much of a different (that we know yet) of VC and VD. VC version works for me and PRL and Profile updates work great. :)
is that what the difference is you can update PRL on one and not the other?
Spot on.
I didn't want to post because my post to thanks ratio was so cool (622 266) :(
Anywho, yes this is the only difference. For those who do not want to go through the update process, I made nROM v1.5.1 and all later versions compatible. All the benefits of VC at the expense of the ability to update PRL and profile.
NOTE: I didn't update. I just update my PRL with QPST anyways. Profile is only really important for account changes and troubleshooting.
For those who did update I put together nROM_v1.5.2_VC.zip which simply has the ability to update PRL and profile. However, any earlier versions of nROM do work with VC basebands.
So to sum it up, VC software was not backwards compatible with v9 at first, but I made a few changes so it could be. Hence the inability to update PRL and profile. Hope this clears up any confusion. Please download the proper version of nROM.
Installed, tried to install androgreen theme, everything got messed up. Now my home button doesnt work and all my contacts and apps are lost. Any suggestions as what to do?
Flash nROM again and you'll be fine.
I re-flashed and all it did was give me back my contacts. My home button and apps still dont work. Any more suggestions please?
Also, my security pattern doesnt come up when i lock my phone. please help me!!!!!!!!!!
What do you mean by your apps don't work? Maybe you should try wiping data and starting fresh.
I was running the LG Optimus S - V9 - with nRom 1.5.2 (Non-VC)
Running Xionia Clockwork Mod 1.2518.4
In Recovery - Made a current backup of my Rom
Downloaded nRom 1.5.2-VC edition and had it on the root of SDCard
Rebooted into nRom and plugged into Windows 7 machine, ran the LG Updater
Updated to version VD through LG updater, about 15 minutes for updating
Phone rebooted into a somewhat nRom 1.5.2
Rebooted into Recovery mode - flashed nRom 1.5.2 - VC edition
Wiped the cache directory
Rebooted - wait while it re-builds dalvik - back into nRom 1.5.2 VC with VD update.
Phone still had root and super-user - no extra hacking required.
Reactions: Nick7
And does everything run fine on VD? This is great. I may consider updating now.
Interested in what VD is! LOL.
another baseband update to fix the lg hang for us that we all had on VC its super easy to upgrade though it just takes a good 20 minutes
How to: Update your rooted V9/VC baseband Optimus S to VD w/out losing all your data.
Yeah apparently this works fine with VD, so upgrade to VD and flash nROM_v1.5.2_VC.zip
Sorry, yea - the 1.5.2_VC has absolutely no issues on the LG - VD version update
I have not seen any boot issues, and it actually seems to be a little snappier than V9
I need to do more testing, but VD seems to have better radio than V9
Status
DannaOgle83
