ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
Probably way too early for feature requests, and not even sure how this works, (would this go in the main CM7 thread or something?), but I find it odd that there is a "JIT Enable/Disable" under Settings->CyanogenMOD->Performance, but no "Stagefright Enable/Disable"...I'm guessing this is because most phones do just fine with Stagefright.
Any chance of inserting an "Enable/Disable" option, or am I stuck with editing build.props each time?
You can request this through the issue tracker as an enhancement...I think.:-\
Well, the problem is, I don't think you CAN disable stagefright on Gingerbread. when i added the =false lines, the player sounded, acted, and responded the same.
Trust me I wanted it off too as it messes up on some of my aac files. Sorry :(
anyone have an issue with incoming calls? Mine seems to take the call fine, but when I go to hang up, it just gives me a black screen, and I have to pull the battery.
It seems to be more twitchy proximity sensor crap. I've had it happen a lot today. Putting my thumb over the prox sensor, (directly to the left of the "sprint" logo on the screen, just down and to the left from the speaker) for a moment and then removing it makes the screen light again. I had a few times when I thought the screen had blanked, and no buttons would fix it, but a flash of my thumb over the prox sensor solved it.
Reactions: dbeckwit
yeah thats the best i can get it for now
Zefie, just got the energy to flash the latest nightly and it works great. Sorry for not doing a lot to help like I want to, being sick makes it hard to do much.
I am having an issue that when I am in a call my screen goes blank and sometimes I cannot get it to come back. it will eventually come back after the call is over and I randomly press keys. any ideas?
there you go
So far looking and working very well..Gapps loaded and working smoothly..
updated from 15 earlier today. works awesome.
odd thing i noticed...while in a call i have the normal options... end, mute, speaker....etc ...but behind them i have a round slider with a send and end option. first time i saw it was when i got an incoming call it was just the round slider till i answered. Then it went to the standard in-call screen in front of the slider. when i make outgoing calls its there too. it still moves but doesn't do anything. I see that it shows up as fixed in the issues tracker... any ideas...is it worth reloading the ROM? when i installed 16 i used the current procedures, the wipe zip, then wiped dalvik and then installed.
I couldn't replicate the error... maybe try clearing /system through Clockwork's built in function then flash?
I had the same issue. Used the wipe zip at first when going from 15 to 16 but still had the problem. It didn't go away until I did a complete wipe in recovery(data/factory reset, cache,etc.) and then install 16.
Did u flash that. Debug-format system. Zip ..(on first post) .flashing that before flashing rom may help
Status
Tfunz
