TR1.8.2 My battery seems to be at about 40% after 8 hours
On TR 1.8.2, and my phone is lasting almost three days with light use (a decent amount of web-browsing, lots of email-checking, a bit of texting/document reading). Not running a custom kernel or anything, and I'm not playing any games on this thing. Maybe that explains the difference?
The post says to update via LG update tool but my LG update says "The Cell phone is the latest version already. So you don't need to update." even though the baseband is V9. I think it is looking at the SW which is VC. I don't know how to get out of V9. ANy ideas? Thanks!
can i get the new layout for the buttons i had to flash TR again and for some odd reason all buttons wake the phone again
reflashed 1.8.2 and my home key does not work will wake the phone but will not work any time other then that tryed to flash the stock button layout still dont work about to try and wipe the whole thing and do it all over
PS i only started to get this issue after trying to install the Xionia OC kernel 013
Is it the ThundeROM that makes it so the phone will only wake up from sleep mode if you press the power button? Is there anyway to change it back to default where you can press any key to wake it up? thanks
When using the LG tool to move the baseband to VD...does the LG tool download that from LG real time?
I have 1.8 installed but phone constantly prompts to do hands free activation. the SW version appears correct but I dont recall updating it to VD prior to my install of 1.8.
I assume I can just update the phone via the LG tool to VD (goes over the internet real time) to get the VD update and then just use recovery to reflash to 1.8 after the update..is this correct?
